0 Members and 1 Guest are viewing this topic. Read 16632 times.
Sorry
I suspect they'll sound quite good. Waveguides and pro woofers can make excellent sound. Jeff Bagby is well regarded. They could be easily tweaked with fancy caps and no-rez. Both inexpensive and well designed.
Thanks JLM!Well lightly sanding the rough 1st coat, diluting the duratex with a little water and using a smoother roller worked great. The finish, while still textured is actually smooth to the touch.
