0 Members and 1 Guest are viewing this topic. Read 9835 times.
Charles, if you build the right power supply, the performance of your unit will not be degraded at all.Dave.
Danny has experience with the unit, and therefore earned credibility. Charles is about to do the same. I like to listen to those with experience with the units in question.
Resorting to the first-hand experience explanation to discount opinions is silly. People with solid engineering backgrounds and experience on many types of equipment can provide knowledgeable input on subjects even though they don't have first-hand experience.
Did you see me discounting Gary's design of this unit?
No, just his choice of power source.
This is the Lab Circle after all.
No I didn't. I said there wasn't anything "inherently superior about a battery supply system."I will stipulate that battery supplies eliminate many potential issues that might be incurred if using a conventional AC/DC supply. But, that doesn't automatically mean they will out-perform the alternative.....either subjectively or in the Lab. (Many variables at work here.)This is the Lab Circle after all. I would be interested in seeing some comparison (lab) measurements of a Dodd preamp powered both by a battery setup and by a conventional power supply setup. That would identify any 60Hz leakage into the audio circuitry and/or other relative issues. Maybe Charles could provide these during his effort? That's objective data that would be interesting.If PS internal resistance is the primary objective here, there are better alternatives than SLA batteries.Subjective evaluations are incontrovertible.Cheers,Dave.
but in the engineering world it's always more complicated than it seems. You CAN achieve excellent results with a conventional power supply setup as well.
Dave, I agree with that as well. My issue with using A/C is the amount of money I have to spend with conditioning and power cables before I even get to the power supply for the piece of gear. I can buy a 100 amp hour battery and charger for less than the cost of one decent power cable.
Do not forget the Batterybuss cost. An essential part IMO. Granted one Uberbuss is $1100 plus PC of choice [ TWL 7+] then six PC to components adds up. Besides the money which is a factor to some which is better in sonic retrieval is the issue here. I will find out soon.charles
Charles,Since this is the lab circle I have to emphasize what some have already mentioned, that the quality and implementation of the DC supply matters a lot. The typical off the shelf 3 terminal chip regulator (LM12xx, LM317, etc) implementations just aren't going to get it done. As Danny said, the necessary level of elegance for a proper LPS can get expensive.I'm not recommending this guy's stuff at all as I haven't tried them, but the articles provide interesting perspective for sonicshttp://www.coreaudiotechnology.com/batteries-vs-linear-power-supply/http://www.coreaudiotechnology.com/faqs-about-our-power-supplies/I've used the KECES DC-115 power supply (since superceded to DC-116) with success for various low voltage applications like the Squeezebox and a Linux server, and have been quite happy with it at modest cost.http://www.keces.com.tw/5_english/index_5_english.htm
Linear power supplies are going to be larger than batteries. But unlike batteries they can be built to a much higher bandwidth that functions consistently. A well-designed linear power supply can be considerably lower noise, faster, and higher bandwidth than any battery. Linear power supplies can filter the incoming AC noise, eliminate ripple to exceptionally high frequencies, and have much higher slew rate and current output. This means their sound will always be consistent and their potential much greater.Comparing a battery to a SMPS or entry-level power supply will put a battery ahead as the clear winner. It will be much lower noise than a SMPS. But a well-crafted Linear power supply has several advantages and should be the only consideration when looking for the ultimate power solution.
Tom,What's in that KECES power supply? All I can see is a transformer and multiple capacitors.Dave.
