Dynaco PAS4 cap mod
0 Members and 1 Guest are viewing this topic. Read 1173 times.
foz1982
  • When I listen to PF the neigbors listen to PF
Dynaco PAS4 cap mod
« on: 30 Nov 2015, 02:30 pm »
Upgrading my preamp before I spend a boatload on a TT rig. To see if it will be better than my cd player.
The stock coupling caps are Wima .10 @400V. I heard good things about the Jupiter copper caps but I am
new to this DIY gig so recommendations are welcome. Also since it is all apart now  any other components
I should replace??? Thank you!
Scott
Jeff
  • Test...
    • Sonic Craft, Inc.
Re: Dynaco PAS4 cap mod
« Reply #1 on: 1 Dec 2015, 12:30 am »
Scott,
If the budget allows, the Jupiter Coppers are an excellent choice  :thumb:
Regarding other components, I'd need to see a couple of pics of the inside.  I have a schematic of course, but that does not tell me what type of components you have now.
foz1982
« Reply #2 on: 1 Dec 2015, 04:07 am »
foz1982
« Reply #3 on: 1 Dec 2015, 04:11 am »
Did not think this was going to work. I just saw typing when posting, no picture
sorry took so long.
Scott
