0 Members and 1 Guest are viewing this topic. Read 12655 times.
What they do to refurb a camera? It is a reliable camera?
same sensor does not equal same photo quality The sensor itself is only part of the story: cameras have A/D converters and SNR code that make all the difference in final image quality. The primary reason we are seeing improvement in low-light performance from modern digital cameras, for example, is not because the sensors produce less-noisy data. They don't. The difference is in the processors and algorithms that create the image. RAW files are not some kind of data dump from the sensor as is often assumed. RAW is just the data dump from the combination of A/D converters and image processing firmware. The image processing firmware has been getting better through adaptation of techniques used in radio astronomy to filter out noise and fill in missing information (where the noise was in the image).I do not have a readout on what differences there are in D3300 and D5300 processors. However, for the very slight price difference, the D5300 has a much better autofocus system and a better LCD screen on the rear.Having said all of that, for very little more than a new D5300 you could get a mint condition D7100 from e-bay for very little more and have a better camera still: http://www.ebay.com/sch/sis.html?_nkw=Nikon+D7100+DSLR+Camera+Body+Black+Refurbished+by+Nikon+U+S+A+1513+B&_itemId=331553740465&_trksid=p2047675.m4099
is buydig a reliable place? I have not bought from them before but they have a good deal on a refurb d3300.Also would it be better to buy the kit with just the 18-55mm ($339) or buy it with the 18-55 & 55-200mm ($399).I am also probably going to buy the 35mm.
I actually think my Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR II does a great job. How much better is the AF-P?I just watched this video - https://www.youtube.com/watch?v=dX7vOYM9grwFrom the above video - AF-P quieter, quicker focus, focus ring closerDownside 55mm ring size if you already have 52mm filters for current lense.Where did you buy the grey market lense?
