bellina with windows 10
0 Members and 1 Guest are viewing this topic. Read 973 times.
alamakazam
« on: 28 Nov 2015, 11:25 am »
anyone able to install any driver for windows 10?
I cant get it to work
embz
Re: bellina with windows 10
« Reply #1 on: 28 Nov 2015, 05:02 pm »
I am running the Bellina Pro driver with Window 10.  I didn't do a clean install of Windows 10, It was an automatic upgrade from Windows 8.1.
To get the driver to work with 8.1, you needed to disable the driver signature and run in compatibility mode.  It was a few extra steps but did work.  Since I didn't do a clean install of Windows 10, not sure if you need to follow the same process or not.
I'm using verison 1.56.0.0 of the driver
Vinnie R.
« Reply #2 on: 14 Dec 2015, 06:15 pm »
All,
The Bellina Pro’s USB input is based on the MiniDSP “USBStreamer” board.
1) The USBStreamer will function fine on Win10. You simply need to remove the driver signing. There are some steps available here:
https://minidsp.com/images/documents/USBStreamer%20Manual.pdf
Please see Page 17 and up to see how to disable driver signing.
After doing this, do the following:
2) Reinstall the Bellina pro driver.  Run the setup.exe file.   It will first uninstall the previously installed driver, and then reinstall the driver again. Confirm that Bellina driver installed correctly with no errors (you can also check via device manager).
NOTE:  During this process you'll have to answer "install anyway" when Windows tells you it doesn't recognize this driver.  This happens two or three times.)
3) Make sure Bellina Pro dac is selected as your default audio device.
I hope this helps!
Vinnie
