0 Members and 1 Guest are viewing this topic. Read 9547 times.
I really think we have to differentiate between extenders and access points here. Extenders usually refers to something you add on to an existing Wi-Fi router. These are access points and you need a router in front of them. You shouldn't have to use the Ubiquiti router, if you already have a Wi-Fi router combo you could just turn the wireless radio off via the interface. That way you're just using the router part. Initially I'll use a Cisco Wi-Fi router in exactly that way, eventually I may change that.
That makes sense. Anyway I just ordered the other one for $70 and it will be here tomorrow. Can always upgrade in the future.I just remembered - arstechnica.com may have reviewed these.
Folks, who are deploying UAP devices are you getting the wireless settings from existing ASUS/Netgear/Linksys/Cisco router or are you going all Ubiquiti Networks for router/gateway also?
I can't say enough good about the system I installed. It's been rock solid, I don't even think about wifi now...it just works.Ubiquiti has recently started gunning for the home market too, although I don't know much about the products. https://amplifi.com/FWIW, I like this company and the way it's run enough that I bought stock and that's been good too.
If I understand correctly, the WAPs plug in to your electrical 120V house grid in place of Ethernet cables? I've seen these type of devices, but have concerns of dumping more noise on to the already noisy electrical power lines. Is that a valid concern?
Good to know, thanks, Steve.I appear to be in a similar situation and perhaps some of you could offer a recommendation? I'm looking to add wifi extenders {WAPs?} to expand the coverage in my house. I have a Century Link fiber feed to the house. It converts to Ethernet at the service entry and runs to a Technicolor C2100T modem wifi router I placed in the center floor plan of our basement. The wifi signal is very weak at either end of our rectangular house and I would like to add a wifi extender to each end (2 locations).I was looking at the Google wifi device and now this Ubiquiti Unifi Ap-AC Lite. My notion is a whole house mesh network is overkill and I'd rather not spend >~$350+ to do this. We run 98% apple devices so 802.11 ac is desired. My notion is the Google wifi's may be overkill ($112 each) especially if I don't need their whole house mesh set up. I'm hoping just adding two of the Ubiquiti Unifi Ap-AC Lites ($80 each) may be the easiest to implement and least costly. ThanksKenreau
I'd post your question on the ubiquiti unifi forum. Don't be intimidated, they take questions from newbies on up to businesses that use hundreds of them. They always have been patient and helpful to me (a novice).https://community.ubnt.com/t5/UniFi-Wireless/bd-p/UniFi
Thanks. I just found this related article on the wire cutter site.http://thewirecutter.com/reviews/best-wi-fi-mesh-networking-kits/
While it's a boring and relatively cheap approach you might be able to solve your problem by simply using a decent wireless router instead of the one built into the all in one unit.
