0 Members and 1 Guest are viewing this topic. Read 9540 times.
That's a really good price ($84)-amazon has them closer to $160. Almost too good...is there a catch, lIke refurb?
I think that vendor on Amazon is trying to take advantage of something in short supply. Web search will see them pretty regularly under $100. Just got off the phone with Baltic. Mine ship tomorrow, but the supply is trickling in to them. Now says end of December availability. Seems they just introduced these, they're not in Ubiquiti's store on website. Forum posts confirm short supply so I guess I'm lucky...I ordered Monday! We'll see.
FWIW, Son in law has a lot of Ubiquiti stuff deployed. He's pretty high on it and would not jump on if it was problematic. If you nose around there's a number of reviews online. Their stuff isn't really geared or marketed to home users, but is finding an audience there anyway. People like good stuff. I hope it works out like I imagine it.Here's a review I just ran across.http://arstechnica.com/gadgets/2015/09/ubiquiti-revamps-its-enterprise-unifi-gear-and-weve-got-some-to-review/
Have any of you heard that routers do not age well? I read somewhere that as wifi routers age, they tend to have more problems. I think my wifi router is nearly three years old.
Peter, TVYankee,Will these Ubiquiti extenders work with a Comcast modem, or do I need to get my own modem/router? The article makes it sound like a special router is required?Thanks!AC
You shouldn't have to use the Ubiquiti router, if you already have a Wi-Fi router combo you could just turn the wireless radio off via the interface. That way you're just using the router part. Initially I'll use a Cisco Wi-Fi router in exactly that way, eventually I may change that.
I believe that one can put a Comcast wireless gateway into bridge mode without calling Comcast. Log into the admin tool and hunt around. I don't remember where the bridge mode setting is as I don't have Comcast anymore.Most people can then add a quality wifi router http://www.pcmag.com/article2/0,2817,2398080,00.asp and they are good to go. I tell folks to stick with the default SSID and security settings unless they have special requirements.
If you have a piece of coax in that room you can use this even if your cable box is hooked up. http://www.shopactiontec.com/collections/moca-ethernet-adapters/products/bonded-moca-2-0-ethernet-to-coax-adapter-twin-pack
So I will have a camera pointed at the audio setup 24/7/365.
This makes me really curious. Audio gremlins? Poltergeists? Mischievous cats? My imagination is...well, imagining!
Got my Unifi UAP up and running as an AP. Setup was fast and easy, no more difficult than any other. That makes me worried that I'm missing something important.Anyway without tweaking the settings or placing it optimally, I'm seeing a 5-10 dBm increase. What I'm really looking forward to is its ability to handle lots of clients at once. I have about 1 dozen in my home, strains the normal wifi, hopefully cake for this one.
ACHiPo,Here is what i would would do if i were you. I would first call Comcast and have them put your modem in bridged mode then i would put this router https://www.ubnt.com/edgemax/edgerouter-x/ in front of your Comcast Modem/router. the 2nd thing after that would be if you dont have a coax of eithernet cable in that room would be use a powerline adapter.http://www.amazon.com/gp/product/B00Y3QPG1A?ie=UTF8&tag=small0c-20&linkCode=as2&camp=1789&creative=9325&creativeASIN=B00Y3QPG1A then put a switch on the end of that so you could hook up all your equipment in your room.If you have a piece of coax in that room you can use this even if your cable box is hooked up. http://www.shopactiontec.com/collections/moca-ethernet-adapters/products/bonded-moca-2-0-ethernet-to-coax-adapter-twin-pack The thing about wifi range extenders is that they are a little wonky. They work but you are not going to get the reliability of the others.If you want more help PM with your number and i will talk you thru some things.
