0 Members and 1 Guest are viewing this topic. Read 9109 times.
What tubes are you using now?[/quoteRussian tubes electro harmonix, tubes work fine but I want to do something internally. Cary Audio contacted me about their services and upgrading the amp, but at $1200 to $1400 doesn't seem like a cheap endeavor;(
+1 on tubes. That's the best bang for the buck. SLI-80 was my first hifi amp. I kept the SED 6550Cs it came with since those were the best production tubes available back then. But I upgraded the 6922 to 1970s Matsushita and I upgraded the sovtek 6SN7s to some nice vintage Sylvania or RCA, iirc. I also changed the Ruby tubes coke bottle rectifiers which flashed all the time to Sylvania NOS. It was an incredible sound. My friend was QC at Cary, he says the stock caps and parts are pretty good in there. The paper-in-oil cap upgrade they offer would make a warmer sound, I don't prefer that. The amp is already warm enough with vintage 6SN7s. Genalex Gold Lion KT-88s or Shuguang Black Treasure KT-88 would be my first choices for current production power tubes. Later on I got some autoformers from Anticable.com because my speakers had low impedance dip in the bass. That improved the bass and overall sound a lot.
What is the rest of your system?
Driver tube (6SN7) will make the biggest difference in sound. I really like the Sylvania 6SN7's from the 60's. For capacitor upgrades you can't really do better than the Jupiter Copper Foil in Paper/Wax for input/output caps. Power Supply caps make less of a difference, IME. They do make a difference, just a lot less than input or output caps.
Rectifier tubes won't make much of a difference.
