Future Bryston CD Player Still A Go?
0 Members and 1 Guest are viewing this topic. Read 201851 times.
R. Daneel
Re: Future Bryston CD Player Still A Go?
« Reply #100 on: 19 Jul 2016, 01:25 pm »
Hi James!
Considering BCD-3 has two DAC chips, assuming one-per-channel, and BCD-1 had one stereo DAC used for both channels, this means the circuitry has been totally redesigned and is now more in line with BDA-2/3 DACs, does it not?
I only wish the "Bryston" logo on the front was CNC-milled rather than silk-creened.
Also, what are your impressions of the Sony disc mechanism now used? How fast does it load the disc?
Cheers!
Antun
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #101 on: 19 Jul 2016, 03:08 pm »
Hi James!
Cheers!
Antun
Hi Antun
Yes the new CD player is essentially a BDA-3 with a Drive.
The Bryston Logo is milled - its just a small line.
The drive is superb - really smooth in operation and quiet.
james
spinner
« Reply #102 on: 19 Jul 2016, 03:17 pm »
 So is the name on the black version  etched as well .....thanks :o
« Reply #103 on: 19 Jul 2016, 03:19 pm »
Yes
james
Rod_S
« Reply #104 on: 19 Jul 2016, 04:56 pm »
james
Any idea how it compares to the Esoteric's VRDS-NEO drives, the VMK-3.5-10 and VMK-3.5-20S or even their lesser model the VMK-5?
« Reply #105 on: 19 Jul 2016, 05:27 pm »
No sorry never used them.  The drive is strictly cosmetic as the CD is lifted out of the drive tray when you hit Play.
james
CanadianMaestro
« Reply #106 on: 19 Jul 2016, 05:40 pm »
james
It's interesting how frequently this fact is overlooked or missed entirely.
The tray has no impact on SQ of BCD. Plastic tray is good -- cheap but reliable and durable.
« Reply #107 on: 19 Jul 2016, 05:44 pm »
The BCD3 Sony drive is available in plastic or metal - we are using the metal tray.
james
CanadianMaestro
« Reply #108 on: 19 Jul 2016, 05:53 pm »
Hi james,
how much extra for metal, and what are the benefits/pitfalls of metal?
thanks
pete
« Reply #109 on: 19 Jul 2016, 05:58 pm »
Hi james,
thanks
pete
More money- no performance advantage -  but looks and feels better
james
rmurray
« Reply #110 on: 19 Jul 2016, 08:12 pm »
That adds to the pleasure of using the player. What if a fine a turntable had a cheap plastic platter? For me that would undermine the overall sense of elegance.
CanadianMaestro
« Reply #111 on: 19 Jul 2016, 10:22 pm »
LOL, a platter is critical for a table's performance, as it spins the LP and needs a certain mass and dampening.....not so with a CDP's tray, as stated earlier.
 8)
rmurray
« Reply #112 on: 20 Jul 2016, 03:49 am »
 You missed my point.
R. Daneel
« Reply #113 on: 20 Jul 2016, 06:21 am »
I've no doubt Bryston BCD-3 sounds spectacular but for ultimate build quality, a spiritual ritual of putting the CD in, I'd go with one of the top players from Denon or Acchuphase.
As for players that are no longer manufactured, Sony's fixed pick-up ES models from the 1990s are simply beyond approach. Not only that CD drawers moved completely silently, Sony even put felt material where the different metal plates of the casing met to ensure everything was perfectly damped and aligned. Quite staggering if you ask me.
But like I said, the BDC-3 would most likely be a sonically more convincing player if my BDA-2 is any indication.
Cheers!
Antun
CanadianMaestro
« Reply #114 on: 20 Jul 2016, 12:35 pm »
 :duh:  I was being too transparent -- taking things literally.
DRK
« Reply #115 on: 22 Jul 2016, 03:04 pm »
Mr. Tanner
Happy to see new CD Player.  Currently own a BCD-1.
Question: Wondered how many tracks the "3" was capable of reading.  I believe my BCD-1 is max'd out at 33 tracks and believe it or not, I do have a several CD's with more than 33 tracks so I've been copying the overage onto another CD as a "work around".  Hoping this has been addressed with the "3".
It is a banner year for new model intros at Bryston.  I wish you much success.
« Reply #116 on: 22 Jul 2016, 03:12 pm »
Mr. Tanner
Hi
This new drive can do up to 99 tracks. :thumb:
james
DRK
« Reply #117 on: 22 Jul 2016, 03:17 pm »
Great.  Age old question.....keep the "1" or upgrade?   Time will tell.
Have a great day
1ZIP
« Reply #118 on: 5 Aug 2016, 11:07 pm »
James;
Must be getting close to a release date?
« Reply #119 on: 6 Aug 2016, 01:43 am »
James;
Yes we have all the parts on order but we are so backed up with other projects that it may be a couple of more months.
james
