Elac B6 upgrade
0 Members and 3 Guests are viewing this topic. Read 52892 times.
Danny Richie
    • http://www.gr-research.com
Re: Elac B6 upgrade
« Reply #160 on: 5 Mar 2018, 03:15 pm »
Hey gkannan,
Yes the heavy vinyl tiles are ideal. And you can place them on the outside of the cabinet if you want. You will have to figure out a way to glue them on.
You can also upgrade the cap and resistor used in the woofer circuit.
I think the speaker terminals that you are referring to are these: http://gr-research.com/electracabletubeconnectors.aspx  Read through that material. It is very enlightening.
