0 Members and 1 Guest are viewing this topic. Read 9243 times.
That could work, but I'm concerned about the little bits of sand and junk coming off the pavers. Any recommendations on what I could paint them with to prevent this? Does it really matter what I paint/stain them with? I don't want debris around my vinyl that could inadvertently get on a brush and end up destroying a record.
Hope it will works for your. Your choices are only lmited by your creativity.CheersHugo
Can the turntable feet be unscrewed and new, lets say points or cones be screwed in instead?
If you don't mind an unfinished look, maybe these? That come in all black, can have cones on tophttp://www.rockler.com/bench-cookie-plus-work-grippers
Thank you Sunny. I dont post much but this is something I thought I could help with. Some further thoughts/tips because not everyone has access to tools.You can go to a Lowes, Home Depot, Menards etc and buy 1/2" or 3/4" plywood sheets. Then get them to cut it to your shelf size. Have them cut (3) shelves for you say...24"x18" each or whatever your self size needs to be. Then, if you dont have a drll press or forstner bits to drill the large diameter "recessed" holes to fit over your nut/washer buy a hole saw (of the dianeter thate you need). Drill the (4) holes using your drill or have a buddy do that for you on (2) of the (3) shelf pieces. The hole saw will cut all the way through it. Then glue those two together carefully lining up the holes. Now glue the third shelf (which has no holes) on top and you end up with a solid top with recessed holes underneath that doesnt require high end tools. Presto!Last tip: ( sorry for the long post)If possible unbolt your existing top shelf and use that to line up the holes on the new shelf you are creating. That way you wont need to guess where They are nor make high precision measurements. Lastly, once you have the position of your holes, take one of the washers and trace it in place so now you know "where" the holes go and"what" minimum diameter you hole needs to be. I recommend making your hole slightly larger.If you want to get fancy you can use different materials for that top shelf to create a multilayer turntable shelf that would isolate different frequency of vibrations depending on the materals (mdf, plywood, corian etc) used in your shelf.Hope it will works for your. Your choices are only lmited by your creativity.CheersHugo
I removed the center support after realizing I could push it either way like you would a Jenga piece. Would extra-thick grunge buster dots help isolate the turntable until I buy better feet for the TT?
n on trying this out with the red granite or onyx I picked up from the local stone and tile shop that I frequent for my yard landscaping. It was a cheap couple of leftover pieces that didn't have to be perfect.
