Parafeed capacitor upgrade for Bottlehead Stereomour 2A3
0 Members and 1 Guest are viewing this topic. Read 1217 times.
borism
Hi Jeff,
I built a Stereomour 2A3 integrated amplifier and originally upgraded both the interstage and the parafeed caps with Mundorf Silver/Oils. Since then I tried various capacitors including the Russian FT3 for the interstage cap (0.1 uf). I ended up with the Jupiter wax/copper foil and found it to be as extended in the highs and bass but fuller in the midrange. This was a clear improvement and was missing with the other caps.
I am wondering if replacing the 3.3 uf parafeed Mundorf with an Jupiter HT flat stack (the copper foil would be to expensive) would provide a similar benefit.
Any thoughts/experiences?
Boris
Jeff
  • Test...
    • Sonic Craft, Inc.
Re: Parafeed capacitor upgrade for Bottlehead Stereomour 2A3
« Reply #1 on: 2 Nov 2015, 02:38 pm »
At the end of the day, the Mundorf is just a metallized polypropylene.  The Russian lacks refinement.
Experience with this application?  I have none.  However, you will find a similar result IMO.
borism
« Reply #2 on: 2 Nov 2015, 02:59 pm »
