0 Members and 1 Guest are viewing this topic. Read 63193 times.
We have these custom made because the ones you buy off the shelf short the pins, as you have indicated. No transformers inside. We have used the transformer based adapters, but they add some distortion and you lose DC coupling that way. Measurements have indicated that balanced is a few dB better in the SNR department, but THD+N is about the same. Output voltage is 2.5VrmsFS using the adapters and 5VrmsFS without. Thanks.
So if yours doesn't short the pins, I'm assuming it is a resistor based attenuation for the rca output then? Or is it a lift on one of the pins?
I built a Shelf unit for my Digital Amplifier Company equipment. The three shelves are 31 x 12 x 2 one piece Red Oak. I made the posts out of raw red oak that I split with tools. I am proud of this piece because it compliments the beautiful Digital Amplifier Components. On the first shelf are the Golden Cherry Monoblocks with an Audio Mirror t-61 tube preamp. On the second shelf are the Golden Cherry power units with the DAC DAC in between. I power a pair of Magnepan 3.6r'. The sound is smooth as silk and textured as Fondue Chocolate. The blackest background. The best instrument staging. So precise and beautiful. Tommy O' you do excellent work. Thank You!!!
I have a Mojo Audio Mystique v2.0 DAC and would be happy to do a comparo if I could get access to a DAC DAC. It wouldn't be a completely apples-to-apples comparison as the Mystique is single-ended output and USB input.I use an Auralic Aries, so I could stream coax to the DAC DAC and USB to the Mystique, and my amp has balanced and single-ended inputs, so I can accommodate having both plugged in simultaneously. Again not an apples-to-apples comparison, but could give my subjective assessment of how the DAC DAC fits into my system and sounds with the rest of my gear vs. the Mystique.
Has anyone compared the DAC DAC (HS or TL) to any of these?PS Audio Direct Stream
I was going to choose the TL versions once the kickstarter project ended. but i'm not planning to use a preamp, just volume control. i'm using LDR based volume control and i'm thinking to go for the HS version right now. I tried a tube buffer in my system and while it had a positive effect on voices and midrange it had a negative effect on dynamics. Highs were rolled of a bit and bass impact not so impressive. Not sure there is any truth in that with the TL version dac. It's just something i suppose i can expect.
