Chrome OS Supported in the PCM/DSD DAC Module?
0 Members and 1 Guest are viewing this topic. Read 2448 times.
artcook
« on: 21 Sep 2015, 11:57 pm »
Asking because I use a Chromebox as my music 'server' and want to just use the USB output of the Chromebook into the DAC Module.   I can't find anything in the specs on the DAC that refers to supported Operating Systems.
Also did a forum search before posting this.
aldcoll
Re: Chrome OS Supported in the PCM/DSD DAC Module?
« Reply #1 on: 22 Sep 2015, 12:47 am »
I remember this coming up on another board a couple years ago.  I think it was Computer Audiophile and the USB out wouldn't work with the DAC at that time.  Things might have changed :scratch:  I would look over there on Comp Audio.
What does the maker of you Chrome box have to say?
Vinnie R.
« Reply #2 on: 22 Sep 2015, 03:10 am »
Hi artcook,
Welcome to the VR forum!
I am not sure about this - let me look into it for you...
Vinnie
artcook
« Reply #3 on: 23 Sep 2015, 06:13 pm »
Vinnie,
Thanks for the quick reply.
The code writers at Google (chromium@googlecode.com) are working with manufacturers to get the Chrome OS to communicate with their DACs.  Because of the nature of the OS, I don't think the manufacturer and/or model of the Chrome computer makes any difference.  I do think that communication should be important to you because there are about a zillion Chrome OS computers out there already, and their popularity is growing.
Just do a Google search for 'Issue 376011.'
Hope that helps.
p.s.  I plan on bringing my Chromebook to RMAF in a couple weeks.  Just to see what happens.....  :)
Vinnie R.
« Reply #4 on: 23 Sep 2015, 06:16 pm »
Vinnie,
Hope that helps.
Hi Art,
Thanks for letting me know.
Sure - bring your Chromebook over and we'll test it on LIO's dac.
Vinnie
