Help Virtue two no power
0 Members and 1 Guest are viewing this topic. Read 1473 times.
ammisco11
  • www.hhgstands.com
    • HHG Stands
« on: 16 Aug 2015, 09:13 pm »
My Virtue two stopped working no power, light.
I checked the power supply and measured 30 volts.
The fuse is still O.K.
Does the board have a reset switch or something or jumpers?
Any ideas of what t look for?
Thanks It's a great little Amp.
xr2
Re: Help Virtue two no power
« Reply #1 on: 16 Aug 2015, 10:59 pm »
I had this happen 2 weeks ago with mine, but it was the fuse.  Hard to spot visually, but $5 and a quick run to the hardware store resolved it.
jseipp
« Reply #2 on: 17 Aug 2015, 12:23 am »
The only issue my Virtue has ever had was also the fuse.  I've found that Seth gets back to me really fast -- emailing Seth would be my suggestion.  I hope that all turns out well.
ammisco11
  • www.hhgstands.com
    • HHG Stands
« Reply #3 on: 18 Aug 2015, 03:14 am »
Thanks for the suggestions.  The Fuse is O.K. I even replaced it just to be sure and still no luck.  I had read some time back about faulty power switches.  Anyone know how to test that?
G Georgopoulos
« Reply #4 on: 18 Aug 2015, 03:36 am »
please post a pic of the circuit,so we can help you,cant virtue audio help you?
G Georgopoulos
« Reply #5 on: 18 Aug 2015, 05:46 am »
Same as the fuses,set multimeter to beep,if the on state is good it will beep!,if the off state is good it will not beep!,the only thing i can help with if have no schematic is a bad connection from power supply rail down to amp,if you dont have a circuit schematic you're only guessing,that's not good at troubleshooting
MAKE SURE the power is off when you do these test,unplug from mains,remove batteries or else
virtue
  • Making audio lovers audiophiles
    • Virtue Audio
« Reply #6 on: 27 Sep 2015, 06:31 pm »
Sorry I haven't checked this for a while.  Email me (seth at virtueaudio) and we'll see what we can do.
