Daedalus Audio Isolation devices
0 Members and 1 Guest are viewing this topic. Read 44157 times.
Daedalus Audio
Re: Daedalus Audio Isolation devices
« Reply #60 on: 16 Dec 2015, 05:26 am »
We are sending out a lot of the DiDs and have not finished the instruction cards for them, so here is card with the basics.
thanks!
Folsom
« Reply #61 on: 16 Dec 2015, 05:44 am »
Formatting is a bit off, Lou. Maybe it needs to be a PDF first or something?
ACHiPo
« Reply #62 on: 16 Dec 2015, 01:21 pm »
Thanks!  it's been a long day.......
A few typos, too.  You may want to proof again after a good night's sleep  :wink:
Daedalus Audio
« Reply #63 on: 17 Dec 2015, 05:07 pm »
always helpful to mention the typos
thanks
audiotom
  • Ground control to Major Tom
    • for everything music
« Reply #64 on: 4 Jan 2016, 06:28 am »
Have mine under my mono blocks - natural tonality in spades
I have another set coming to experiment with sources and the pre amp
ACHiPo
« Reply #65 on: 4 Jan 2016, 02:03 pm »
I have a set under each AtmaSphere amp.  I haven't had a chance to do much critical listening, but so far I like what I'm hearing.  Because I need my amps a little higher, the DIDs are actually on top of some other ball-bearing isolation devices (Isopods) that I'll be reviewing at some point.
MegaHz
« Reply #66 on: 6 Jan 2016, 01:54 am »
They are not for use with speakers. There are different forces at play and they really don't help under a speaker. That being said  I have been working on a design that does work at least with my speakers. So far we are making good progress and should have some prototypes ready in a couple of months.
Lou,  Can you give us some insights on your current thinking of what types of devices work for your speakers?
Daedalus Audio
« Reply #67 on: 6 Jan 2016, 05:39 am »
We are currently working on prototypes for speakers, so far so good  :thumb:
We should have a couple variations available in about two months.
thanks,
lou
ps I have had one person put the DiD's under their platform that their TT is on and they said it worked out great. I would love to get more feedback on that if others get a chance to try?
ACHiPo
« Reply #68 on: 6 Jan 2016, 05:48 am »
That's next on my list...
MegaHz
« Reply #69 on: 6 Jan 2016, 05:59 pm »
thanks,
lou
Good to hear, Lou. We'll stay tuned for the next progress report.
Daedalus Audio
« Reply #70 on: 7 Jan 2016, 05:29 am »
ok here is what will go to print for inclusion with the DiDs.
tonyptony
« Reply #71 on: 9 Jan 2016, 02:14 am »
Got mine today. They look great. Need to decide which piece of equipment goes first - my amp, preamp, or phono preamp?
audiotom
« Reply #72 on: 9 Jan 2016, 08:43 pm »
Try them all out
Are you using tubes?  Generally they are the most sensitive
My guess would be the pre amp
What gear are you using?
kingdeezie
« Reply #73 on: 9 Jan 2016, 08:48 pm »
Anyone have dimensions on these?
I need some footers for my Lampizator DAC, which has some long native feet installed.
Daedalus Audio
« Reply #74 on: 9 Jan 2016, 09:20 pm »
they are 1 7/16" tall
is that tall enough?
kingdeezie
« Reply #75 on: 9 Jan 2016, 09:25 pm »
They just might be. I tried some Herbies Tall Tender Feet which are 1.18 inches, and they were just a bit short.
How many would you recommend for a component that its over 20 inches long? Or, is three sufficient for everything?
tonyptony
« Reply #76 on: 9 Jan 2016, 10:02 pm »
Try them all out
The amp should go first, maybe. AVA 600R; it's a hybrid with 12AT7s in the front. Then I think the XP-15 phono pre since it's dealing with very small signals. I guess the XP-20 might be last by that logic, but wouldn't doing the preamp first - even if the amp has tubes in it - make more sense?
Daedalus Audio
« Reply #77 on: 9 Jan 2016, 10:28 pm »
It really varies for each system which component with DiDs makes the biggest difference.  It seems that for some reason DAC's are first  but I have heard it make a huge difference with some tube power amps.... I would through assumptions out the window and just try each piece.
thanks,
lou
Daedalus Audio
« Reply #78 on: 9 Jan 2016, 10:29 pm »
Three should be just fine, we have used three with much larger gear.
thanks,
lou
audiotom
« Reply #79 on: 10 Jan 2016, 02:16 am »
Lou has obviously had a vast amount of experience developing, testing and demoing these
Being so system, rack and room dependent definitely try them with each component
trial and error - live with each for a few days
Note the changes with each then send Lou your next check for another order
Don't sell a phono pre short
Particularly if you are mostly analog.
The signal in a phono stage are the most sensitive and have the highest gain
« Last Edit: 19 Jan 2016, 02:39 am by audiotom »
