Golden Tube SE40
0 Members and 1 Guest are viewing this topic. Read 3553 times.
nzlowie
Golden Tube SE40
« on: 17 Jul 2015, 01:16 pm »
Hi all, about to buy an SE-40.... The old guy selling it tells me it's in really great condition and runs sweet. Going to check it out this weekend, what should I check for?
If I do get it what mods should I look at doing? I can do all these mods myself as I'm pretty experienced with a soldering iron.... Built many amps over the years.
Thanks Dave
Jeff
  • Test...
    • Sonic Craft, Inc.
Re: Golden Tube SE40
« Reply #1 on: 21 Jul 2015, 07:31 pm »
Hello Dave,
My apologies for the late reply, but I was waiting for you to update your status.  I understand you have already purchased the amp.
If you had not already purchased the amp, I would say the first thing would be to figure out what version it is.  The best thing to do is to take a well lit pic of the bottom of the amp.  With the bottom off of course.  The photo should be straight on, and reasonably detailed.  If you send me the pic, I can tell you everything there is to know about this amp.
Since you have requested upgrade info, please send me the pic above, and a brief list of your desired results.
Please advise,
Jeff
nzlowie
Golden Tube SE40
« Reply #2 on: 27 Jul 2015, 04:54 am »
Well, just purchased this amp and thought it sounded ok without being special.
After a lot of reading about the issues I thought I'd have a look inside and see what I've got. Found the bias for all tubes had been would right back to the minimum.
Reset them all to 600mv (no load) without any issues. Did a bit of wiring housekeeping and put the cover back on.
Turned it on once back in the system and WOW, this is I think what it should sound like. A different amp.
All was good for about 15-20 mins then one channel turned bad real quickly, opened my eyes to see all tubes on one channel glowing like a light bulb! Jumped up and turned it off.
Waited for it to cool then turned it on again, sweet sound once again, I didn't wait for it to go into thermal runaway again.
So what do we need to fix the thermal runaway first? Once we address this i'll look to do the reliability mods as directed by Jim.
Thanks Dave
Scott F.
« Reply #3 on: 27 Jul 2015, 12:13 pm »
Your bias is set too high. That is what caused the run away. EL34s should be biased between 30 and 40mv at idol.
Jeff
  • Test...
    • Sonic Craft, Inc.
« Reply #4 on: 27 Jul 2015, 04:24 pm »
Well I hope you are not using EL34s  :lol:
First, the tubes that have run away are now junk.  They may not test that way on a tester, but these amps run a 6L6GC harder than they should be run.  If you bias too low, the amp will lose all of its magic.  For the fast and dirty bias, powering up the amp, allow 3 minutes for warm up.  You will begin the bias process rotating the pots counter-clockwise as necessary for increased bias and vice-versa.  Bias 610-615mV.  Only allow a seven minute window of adjustment.  If the unit is on longer than 10 minutes collectively, shut it off until cool to the touch (about 30 mins.).  Try again.
Before doing this, R43 will need to be replaced.  It is one of the cathode resistors.  You can see it discolored in the photo.  That is one of the parts in any of our kits.  5% of the time, the output trans will be lost before the factory resistor gives up.  You do not want that.  Further, it is not uncommon for them to ignite the circuit board.  The numbers you are reading while biasing, are the voltage drop across the cathode resistor.  So you have no idea what you are actually biasing V6 to, and the tubes on that side of the amp are heat distressing the output transformer.  Personally, I would not continue to run the amp.
All of those electrolytic capacitors are at least 20 years old.  The Cathode resistors are over sized.  Other resistors are either under sized, over voltaged, or the wrong value.  At least two resistors are transposed, and one trace error exists.  D9 is a ticking time bomb, and C7, C26, C46, or C48 are likely over voltaged every time the amp is started due to no centering resistors or power supply regulation.  The amp is hard to bias with 270 degrees of carbon film on a plastic substrate (the bias pot).  Around $150 worth of parts, and a new set of tubes is my recommendation.
Scott F.
« Reply #5 on: 27 Jul 2015, 06:21 pm »
 :duh: My bad...I thought it used EL34s rather than 6L6s....I'll go away now.... :oops:
Jeff
  • Test...
    • Sonic Craft, Inc.
« Reply #6 on: 27 Jul 2015, 06:30 pm »
 :lol:
Its Monday, so you can claim a mulligan  :wink:
Thank you for trying to help  :green:
dBe
« Reply #7 on: 27 Jul 2015, 09:01 pm »
+1 on the don't use it until you fix it.
The SE40 can sound close to, if not magical when the issues with them are fixed.  Smoked some cathode resistors in mine before I figured out that there were congenital defects with the amps in every revision they made.
Red plate = junk thereafter IME.
Dave, too
Jeff
  • Test...
    • Sonic Craft, Inc.
« Reply #8 on: 4 Aug 2015, 09:08 pm »
Well, I think we lost him  :dunno:  :lol:
dBe
« Reply #9 on: 5 Aug 2015, 01:35 am »
I sure hope he isn't trying to use it.
BOOM.
ampmedic
« Reply #10 on: 8 Aug 2017, 07:21 pm »
In the above pics it appears that the R56(?) in the bias supply is paralleled w/another resistor. What is that r value & why??
