0 Members and 1 Guest are viewing this topic. Read 23555 times.
And you could help, for a few dollars more, right ?
Martin, please don't keep your comments to yourself.I'm sure Richard will appreciate your thoughts.
I am currently using a simple coiled inductor to fade the frequencies above 250 to 300 Hz for the bass drivers that I had around from previous driver combinations. The Lowther’s are allowed to play full-range. I see, Martin, that you are suggesting the use of a filter to fade out the lower frequencies of the Lowther’s. The small baffle area the Lowther’s now occupy seem to be doing some of that through natural cancellation.I hope that as a community, each of us can feel entirely free to share our opinions with each other. My knowledge of speaker design is minimal, especially compared to Martin, and so many of you on this wonderful Opened Baffle forum.
I am currently using a simple coiled inductor to fade the frequencies above 250 to 300 Hz for the bass drivers that I had around from previous driver combinations. The Lowther’s are allowed to play full-range. I see, Martin, that you are suggesting the use of a filter to fade out the lower frequencies of the Lowther’s. The small baffle area the Lowther’s now occupy seem to be doing some of that through natural cancellation.The bass drivers can certainly use a boost to help with the cancellation inherent with OB designs. Even box-speaker designs like Harbeth have used the 'BBC-boost' in the low frequencies for years to give a sense of warmth and fullness to the bass.
The point I am trying to make, Martin, is why would I want to 'fix' something that works?
To make it work better. You seem to be focused more on cost and name recognition than design and performance. To spend all that money on drives and fancy tube electronics and then pay almost no attention to the connection and distribution of the signal seems very inconsistent. Personally, I don't care about looks or name recognition. I want the best performance I can achieve for the dollars I have available and using my own design capabilities.
