VMPS RM40 Wire type
0 Members and 1 Guest are viewing this topic. Read 1686 times.
ZAKski288
VMPS RM40 Wire type
« on: 13 Jul 2015, 09:50 pm »
Does any one know what the difference between the two, Bolder wire and AP silver wire?  Thanks ZAK
« Last Edit: 14 Jul 2015, 06:14 pm by ZAKski288 »
Stimpy
Re: VMPS RM40 Wire type
« Reply #1 on: 14 Jul 2015, 06:49 pm »
The Bolder silver wire was offered as an upgrade option, over the standard Teflon silverplate wiring.  But, I 'think' the Bolder wire was only used on the bass/woofer section, or in stand alone subs.  Some info here, from the old VMPS website.
"Crossovers in all our systems are executed at the high quality level, with Teflon silverplate
wiring, Erse “Super Q” coils, and Axon and custom polypropylene capacitors. We can think of only one way to improve on these parts: superpremium capacitors from Audience (Auricap) and TRT, parts too expensive for use in many of the costliest high end competitors including, unbelievably, those retailing in the six figure range."
"Bolder silver wire from crossover point to bass driver on any loudspeaker or subwoofer. More clarity for bass range."
Scroll down to the Upgrades & Options section:
http://pointillistic.com/vmps-audio/loudspeakers.htm
John Casler
« Reply #2 on: 27 Jul 2015, 08:12 pm »
Brian used basically two brands of Silver Wire:
Analysis Plus
Bolder
Usually on the Price list it was listed as as the SUPER MAX option at $700
SUPER MAX meant fully wired with Silver.
AP = Analysis Plus
It was also not unusual for Brian to use Silver going to the woofer section and not even tell you you had it.  If it was closer than the copper on the work bench, and he could reach it easier, you might have silver on your woofs.
If it is listed on the back, then you "for sure" have it.
ZAKski288
« Reply #3 on: 27 Jul 2015, 11:10 pm »
Thanks, John and Stimpy for your detailed information.  ZAK
