Help Me With My Initial Order
0 Members and 1 Guest are viewing this topic. Read 2072 times.
LP1
« on: 20 May 2015, 03:42 pm »
I recently had my new horns installed in my dedicated room and a few tests revealed that the room is desperately in need of absorption from 100Hz-2000Khz. Below is the et60 time for the room. As you can see, it's in excess of 600. I'd like to bring it down to approximately 250.
Accordingly, I plan to initially order a combination of 244 and Monster Bass Trap panels. My room is approximately 18 x 30 x 9.5. Everything below 90Hz will be controlled by my Crown dsp amp, but I'm still interested in treating the room at those frequencies.
I am seeking recommendations for the number of panels I should start with and whether some/all of them should have a scatter plate.
Thanks.
Glenn Kuras
Re: Help Me With My Initial Order
« Reply #1 on: 27 May 2015, 03:24 pm »
Sorry about the wait on this.  I would recommend you email use some pictures and other info about the room so we can come up with a plan for you. You really can't use a RT60 equation for smaller rooms. That is used for LARGE rooms.
See the following link that will give use most of the information we need on your room.
http://www.gikacoustics.com/acoustic-advice/
J-Pak
« Reply #2 on: 14 May 2016, 04:23 pm »
Sorry to bump an old thread, but thought I would ask- what room size does it take for RT60 to start to be meaningful? Cheers
