0 Members and 1 Guest are viewing this topic. Read 19200 times.
Unless you do a double-blind A/B test, there is no way to separate real difference in sound perception from placebo effect. Opinions are not the same thing as facts.
Actually, lower end MKP type caps like Solen are horrible, but 100 uF is huge for a film cap and can get very expensive. Maybe Rick will comment on bypass caps instead of using huge/expensive film caps for such situations?
Audio is highly subjective, so opinions are all we've got. Double blind A/B tests are useless here.
Kishore - you also have to consider the entire chain. For instance, if the components consisted of mid-fi gear with cheap cables, then placing premium crossover parts in a speaker will be of little to no benefit.
I'm listening to "horrible" Solen caps right now - f'n amazing sound! Like anything, it's about the design and execution.
I'll use Clarity caps if I can. Maybe they sound a little better than Solen or Dayton caps, maybe they don't, I just do not know. But they do not cost a whole lot more than the lower-cost caps, and until I have definitive information as to whether they sound better or not, I'll err on the side of caution and spend the extra $40 (or so) and get the Clarity caps. Why not, I figure.I wouldn't spend $600 EACH for Dueland cast-copper or etc., but I will spend forty bucks to buy a supposedly better brand than the "cheapies." Whether or not the Clarity caps really do sound better, certainly there is an emotional satisfaction in using a cap that many consider "better."Some day I will have to devise an A/B/X test for crossover caps so I can KNOW if they sound better or not.Rick may be right. As long as they are film caps, they might sound all pretty much the same.
I think you're on the right track and will get the best value using Clarity ESA caps. I've done one xo with them and it transformed the speaker, AMT RM3s with the Heil tweeter. The stock xo was old so I can't attribute it all to anything specific but the results were far better than expected.
Audio is not immune from the laws of reality.
