Paradigm upgrade...
0 Members and 1 Guest are viewing this topic. Read 2469 times.
germay0653
Paradigm upgrade...
« on: 12 Apr 2015, 01:30 am »
Looking to improve stock crossovers for Paradigm Studio 40, CC and ADP V2.  Any suggestions on where to start first and what would provide the most bang for the buck?
Jeff
  • Test...
    • Sonic Craft, Inc.
Re: Paradigm upgrade...
« Reply #1 on: 12 Apr 2015, 03:13 am »
I'm sure, but I need to see a schematic for each.  I'm sure if you google it, you'll likely find something.  If you possess the skill, you could draw them.  If you would like us to do it free of charge, just sent them to us.  You would merely be obligated for return postage.  If you settle on some parts, we could even include them with the return.
germay0653
« Reply #2 on: 13 Apr 2015, 12:32 am »
I will try to pull out the crossover and take some pictures and capture the cap, resister an inductor values.
Jeff
  • Test...
    • Sonic Craft, Inc.
« Reply #3 on: 13 Apr 2015, 01:00 am »
That may only do so much good.  I would consider committing to drawing a schematic, or shipping them off before you decide to pull them.  Just an FYI :)
