Simple maintenance for your VMPS speakers that can improve the sound
0 Members and 1 Guest are viewing this topic. Read 1076 times.
John Casler
Just received an email from a VMPS owner.
Hi John and Happy Easter.  I just replaced all of the Lpads in my RM40s on a whim as general maintenance.   The tweeter pads were original 14 years old and the midranges probably 6 years old.  It is a noticeable improvement.  Just a suggestion for older RM40 owners.
This also reminds me, to remind you to at least once a year, take your L-Pads and rotate the shafts all the way clockwise and then all the way counter clockwise maybe 20-30 times.
This helps clear off any oxidation or corrosion on the contact points.
Just be VERY CAREFUL in the turning process, as the shafts are rather delicate.
mjmessina
My L-Pad on one of my RM30 was not turning correctly.  I purchased a replacement part from part-express:
           http://www.parts-express.com/speaker-l-pad-attenuator-100w-mono-1-shaft-8-ohm--260-265
Part number match exactly to the one I replace.  Turned out there was glue stopping it from turning and it was not defective.
