Tube Amp w/HT3's
0 Members and 1 Guest are viewing this topic. Read 2835 times.
dwolek
Tube Amp w/HT3's
« on: 31 Mar 2015, 08:18 pm »
I think we can all agree that HT3's like power.  With that in mind, has anyone had success with any modestly priced tube amplifiers (not integrated).  I could imagine the likes of Manly 250, VTL Wotans etc. would be fine but $$$$  Perhaps Rogue 180's might fit the bill.  Anyone with any actual experience with higher powered tubes care to give their experience.  Currently using VTL 2.5 pre --> DNA 225
Cheers
Freo-1
Re: Tube Amp w/HT3's
« Reply #1 on: 31 Mar 2015, 08:53 pm »
Check these out:
http://www.tubes4hifi.com/bob.htm
The 125 watt monoblocks could be just the ticket.  I would think they would have enough power.
Carl V
« Reply #2 on: 31 Mar 2015, 09:05 pm »
Voltage swing is critical.
An acquaintance has had good results
with Music Reference RM9x2 then onto the
bigger RM-100. He had tried my cj MV52
as vertical biamp. Moved onto Gary Dodd's
bigger MONO blocs. Those all worked ok.
Once he settled into the RM 9 & RM100
he was pleased.
Rocket
« Reply #3 on: 1 Apr 2015, 10:48 am »
Hi,
The HT3's sure do like power.  I use Ampzilla 2000 mk II's which I specifically bought to use with these speakers.  I was surprised to see the LED clipping lights come on during music which has deep base.
Good luck with a tube amplifier I'm sure one will be suitable.  I think Frank Van Alstine uses one of his tube amplifier with good results.
Cheers Rod
zybar
« Reply #4 on: 1 Apr 2015, 11:37 am »
It is really going to depend on size of your room, level you listen at, and type of music you play.
I tried multiple tube/tube hybrid amps with the HT3's and it can definitely work.  Ultimately, I did think a big ss amp was the best sounding partner for the HT3's.
If you do a search on my posts, you can read about my experiences.
George
Big Red Machine
« Reply #5 on: 1 Apr 2015, 01:27 pm »
I had decent luck with Dodd tube mono blocks at ~120 watts each.  It is a black hole of power consumption into those 3's.  Still love them as great speakers though.  My first of 7 pairs of Salks were HT3's.  Ah, the memories....
dwolek
« Reply #6 on: 2 Apr 2015, 02:45 pm »
Well my room is large-ish as about 22x30 and I do enjoy fairly loud volumes, so based on these responses, I don't think it is a worthwhile endeavour to pursue a tube amp.  The DNA 225 seems great, but there is some high frequency harshness.  Thinking of either getting a SmC revision done or maybe just go for either a DNA 500 or AVA Fet 600r as both of these come available used periodically.
ernest787
« Reply #7 on: 2 Apr 2015, 03:04 pm »
I just bought a AVA 600r used about a month ago and I can't recommend that amp enough.  It powers the HT3s wonderfully and really seemed to open them up.
Big Red Machine
« Reply #8 on: 2 Apr 2015, 03:06 pm »
Now that I own one, I'd suggest you try Electrocompaniet amps.  Smooooth and powerful.  I am happy to have a PM discussion about amps and anything Salk.
Ern Dog
« Reply #9 on: 23 Apr 2015, 03:46 am »
Another suggestion is to keep your amp but roll in some warmer sounding tubes into your Vtl preamp or try a Sablon Robusto power cable to bring in more warmth to temper your harsh highs.  The Sablons are superb power cables.  Here's a review which includes the Robusto: http://www.positive-feedback.com/Issue68/sablon.htm
