0 Members and 1 Guest are viewing this topic. Read 5477 times.
I had hoped to use the Oppo to downmix DD from the HMDI input to the TOSLINK output, but that limits me to the 16 bit/48 kHz capability of the Oppo's TOSLINK output.
JRace - yes, that approach would get the signal out, but I'm not sure it would be much better than just accepting the 16-bit/48 kHz limit of the Oppo.Phil - the HD577, and the newer HD570, don't explicitly mention the ability to downmix from multi-channel to stereo. The only device that I've found that converts Dolby to PCM and mentions downmixing is the PureLink HEXA-01, but there is little in the way of reviews on this unit. That said, at $500 list price, you're starting to hit the price level of several full-on AV processors...Thanks to you both!
Another Atlona product that may work for you.I would chat with their tech people to confirm the max output from the coax jack.AT-HD4-V41
