single width SACD player?
0 Members and 1 Guest are viewing this topic. Read 2014 times.
grsimmon
  • Omni - the best way forward
« on: 17 Mar 2015, 04:34 pm »
Does any company out there make a single-width SACD player?   Or maybe it's called  "half width" like some of the Bel Canto components.    This would be for a bedside headphone rig with limited space.
Phil A
Re: single width SACD player?
« Reply #1 on: 17 Mar 2015, 04:46 pm »
I know Linn's older discontinued units were that size.
Phil A
Ron D
« Reply #3 on: 17 Mar 2015, 05:37 pm »
Denon used to offer a smaller width unit. maybe about a foot wide?
Denon DCD-CX3 CD / SACD Super Audio CD Player
Can't say if it was any good or not but if you found once in decent shape and the footprint matched up it might work for you????
grsimmon
« Reply #4 on: 17 Mar 2015, 07:35 pm »
Yes,  something like that Denon is what I had in mind
Phil A
« Reply #5 on: 17 Mar 2015, 08:34 pm »
It's too bad the Teac will just play DSD files on a burnt DVD as it would be perfect otherwise - http://audio.teac.com/product/pd-501hr/
ACHiPo
« Reply #6 on: 18 Mar 2015, 03:13 am »
Didn't Naim make a small CD player with a separate power supply?
Phil A
« Reply #7 on: 18 Mar 2015, 03:16 am »
Believe they did but the OP indicated SACD player and I'm not sure that the Naim did SACDs.  I know the Linn Unidisk players did
windhoek
  • Live life like you're gonna die, cos you're gonna!
« Reply #8 on: 18 Mar 2015, 08:27 am »
And now for a highly unorthodox option...how about buying an in-car sacd player such as the Sony MEX-DV2200 and powering it via a DC transformer and connecting speakers to it. It doesn't seem to have a headphone Output, but does m/c decoding! I think it's out of production, so you'd probably have to buy a used one. There might even be another in-car sacd player that does have a headphone output, I don't know,  the Sony was the first option that came up on Google.
ACHiPo
« Reply #9 on: 18 Mar 2015, 01:16 pm »
:duh:  In the immortal words of Emily Lattella, "Nevermind".
