0 Members and 1 Guest are viewing this topic. Read 5555 times.
I have a Synology 1513+ and an add on DX513 5 bay unit (total 10 bays). I'd get a DS415+ (4 bays with add on capability, hence the "plus"). It's quad core and plenty of memory for less than $600 (diskless). My dual core is plenty and I do everything (Jplay, JPlaystreamer, Rendu, Minimserver, Buuble Server, etc)..
Ted,It was recommended to me to go with a Synology 1515+ as the dedicated server for my Rendu SSR. Is the DS415+ capable of the task? That's a much better price. Thanks.
The only thing I misspoke about (and don't understand Synology about this) is that although the 415+ is a PLUS, it doesn't expand. So it is 4 bays, period. If you think you might need more than , say, 4x4TB (16TB, likely 12 with RAID failover...although they accept 6TB discs too, so then 24TB and 18TB with RAID failover) then get a true expandable one like the 1515 (or even the dual core 713+ that starts at 2 bays and goes to 7).
CyberPower CP1000PFCLCD (sine wave) UPS
The new Nasware should read 3.0 not 2.0(older model).
I just added a Synology 1815+, 8 bays, 4tb drives as SHR. I added a CyberPower CP1000PFCLCD (sine wave) UPS for the NAS, switch, router, VOIP phones, and modem and it all draws less than 100w. It was very easy to set up and so far it all works well together. I combine audio, home office, backup, archive, photos and portfolio stuff, personal cloud service, and remote management access, with a lot of local devices, and it has no effect that I can tell on audio performance. It's really not even breaking a sweat.
