0 Members and 1 Guest are viewing this topic. Read 3854 times.
Very nice! Did you install the IR Sensor?
Thanks! Yes, I did install the IR sensor. It works although I'll probably have to extend the leads a bit because the wiring harness partially blocks the direct line of sight. I'm not sure if the 3/4" redwood is disturbing it too. I might have to create a more direct path by drilling a hole in the faceplate. I'd rather not do that.
Very nice. I personally prefer a metal enclosure to protect from EMI/RFI.-Roberto
Finally finished this and it sounds wonderful. A machinist friend has volunteered to build a brass knob. Alternatively, I could go for a wood knob from DKnob. http://dknob.com/index.html https://lh4.googleusercontent.com/-6OCaOceSGh4/VPDPnEi_D0I/AAAAAAAABjc/SnYtEBmj30Y/s800/P1080488.JPG?gl=US
