0 Members and 1 Guest are viewing this topic. Read 16580 times.
I'll report back after heavier listening… but as far as I can tell, she's a keeper. Good work, Vinnie… a spectacular achievement indeed!
Question: was there a design change in the tube stage, or am I going nuts? Originally I thought it was advertised as having two gain settings...
Got a little bit more listening in last night, really sounds great so far... not that I expected any less from you, Vinnie, but I feel like the DAC really shines compared to most 'built in' integrated DACs that I've heard.
My only qualm would be that the driver should be posted in a .zip format for PC users since it is native to Windows. The .rar file required me to download an unpacking software to extract it - no big deal for a software guy like me, but an extra step nonetheless. But once I had it set up and configured Media Monkey's WASAPI output correctly it worked without a hitch.
My KEF LS-50's sang like I've never heard before - not even in a showroom demo.
but right out of the box the LIO is performing well beyond my expectations. I want to thank Vinnie for putting together what is likely to be the best piece of audio equipment I've ever owned. I'll be selling off my old components and now useless cables in the coming days so I can spend the extra money (and time) on music. I couldn't be happier. Keep up the good work.
brh and timkolacny thanks for your impressions.What is the module configuration in your Lio's?Chris
Page 6 is up (http://6moons.com/audioreviews2/vinnierossi/6.html).Vinnie - I realize the review is not complete yet but I wonder if you could check with Srajan to see about something. I think he did a decent job comparing the sound of the AVC and the RVC-with-tube-buffer. The ending paragraph on p6 is not clear if he has done this yet; but I'm wondering how he might compare the sounds of AVC and RVC with not tube buffer.So, in the end, we'd have three clearly defined reviews: AVC (no tube of course); RVC (no tube); RVC (with tube).Very glad to hear the HE-6s shine on the Lio! Anyone want to buy an EF5 headamp, Sig16, Burson DA-160 DAC + a bunch of cables? No one reading the Lio threads! Thanks
To suss out its performance, I'd use my €9'000 COS Engineering D1 DAC/pre as the 'bypass' control unit with 256 x 0.25dB step resistor-ladder analog volume. LIO as AVC preamp would then contrast against the D1 in fixed-output mode and my Esoteric C03 transistor linestage. Part 2 would swap in LIO's RVC module. Part 3 would add the tube stage and contrast that against my Nagra Jazz valve preamp.
Hi Vinnie: Speaking of the 6Moons review, Srajan wrote: "Where it goes beyond its various precursors is with that single no longer twinned display. It converts to temporary balance mode whenever the remote's left/right arrows are used to lock in up to 12 steps of level offset. Then it reverts to regular volume again which now ramps up and down at the set balance difference." I always liked the idea of a dual volume display, one for each channel, but understand it's not always practical. Can you a post a photo of the display showing what it looks like in "temporary balance mode"? I would like to get a feel for what it looks like in operation. Thanks! Gerry
Hi Gerry,I personally am not fond of the dual display for L and R volume. Too complicated looking (just my opinion). John developed firmwareto allow for one display, and using the balance control it allows you to offset the volume up to 12dB (in 1dB steps). Once you do this, as Srajan mentions above, it then goes back to displaying the volume level. But you can adjust it at any time via the remote. Really slick interface! [...]
