2b-LP
0 Members and 1 Guest are viewing this topic. Read 1004 times.
DepthAfield
2b-LP
« on: 7 Feb 2015, 07:30 pm »
Hello all!
Noob question here... one that I've no doubt already been addressed somewhere on the forum, but I've had little luck with the search feature.
Anyway, I'm in the process of piecing together what I hope will be a respectable 2 channel system based around the 60 watt 2B-LP amplifier. Might the group have speaker and pre-amp (with phono) suggestions? My listening space would be considered medium sized, my musical taste is fairly eclectic but leans toward classic rock.
Like most folks, I am budget limited and want the best bang for the buck. Would prefer to not spend over 2K (US) on speakers. As for a pre-amp, I am thoroughly confused... not sure what features I really need (other than a phono input).
Many thanks in advance for any suggestions!
ServerAdmin
Re: 2b-LP
« Reply #1 on: 8 Feb 2015, 11:13 am »
Greetings, your post didn't meet Cheap and Cheerful guidelines so I have moved it to All Solid State.
if the 2B-LP is a Bryston amplifier, then you should probably post in the Bryston Circle. - http://www.audiocircle.com/index.php?board=57.0
