LDR3.V2 Passive Preamp - 3 RCA Inputs - Dual RCA Output
0 Members and 1 Guest are viewing this topic. Read 12072 times.
tortugaranger
    • Tortuga Audio
Finally getting some new product pics. Here are a few shots of the LDR3.V2 with silver face.
Re: LDR3.V2 Passive Preamp - 3 RCA Inputs - Dual RCA Output
« Reply #1 on: 3 Feb 2015, 10:00 pm »
I like it  :thumb:
WireNut
« Reply #2 on: 3 Feb 2015, 10:09 pm »
I think it looks awesome. Wish it was available in a 17-19'" wide unit to match the rest of my equipment.
TJHUB
« Reply #3 on: 3 Feb 2015, 10:52 pm »
Looks great!  I can't wait to get mine.
tortugaranger
    • Tortuga Audio
« Reply #4 on: 3 Feb 2015, 10:55 pm »
Actually those pics are of YOUR unit which goes out the door first thing tomorrow morning.  :thumb:
TJHUB
« Reply #5 on: 3 Feb 2015, 10:58 pm »
Ha!  I just emailed a friend stating that that could even be mine.  Looks like I was right.  :D
tortugaranger
    • Tortuga Audio
« Reply #6 on: 3 Feb 2015, 10:59 pm »
Well, the extruded box we use is 6" wide so 3 together would be 18" and we could easily fabricate matching front/back panels. Lots of extra aluminum housing air, but doable.  :lol:
TJHUB
« Reply #7 on: 3 Feb 2015, 11:23 pm »
It would be nice to see pics of a unit powered up.
robertopisa
« Reply #8 on: 4 Feb 2015, 03:53 am »
Nice, I like it except the fact that the black screws are not on level with the face plate. They contrast too much  with the minimalist style of the plate, which is nice. Also for the knob I would use a simple cilinder rather than the carved one. Just my two cents :)
Cheers
-R
Magnatest
« Reply #9 on: 4 Feb 2015, 12:07 pm »
A more flush look can be achieved by replacing the screws with button head screws.
TJHUB
« Reply #10 on: 4 Feb 2015, 12:30 pm »
Better yet, I plan to use these flat heads:
tortugaranger
    • Tortuga Audio
« Reply #11 on: 4 Feb 2015, 01:30 pm »
Nice looking bit of hardware. Who makes/sells them?
TJHUB
« Reply #12 on: 4 Feb 2015, 01:33 pm »
You can get pretty much anything like this from McMaster Carr.
tortugaranger
    • Tortuga Audio
« Reply #13 on: 4 Feb 2015, 01:38 pm »
True enough. They are also consistently the most expensive supplier of everything as well. Always looking for alternatives.
TJHUB
« Reply #14 on: 4 Feb 2015, 01:41 pm »
It's not so bad when you're not a manufacturer.  :wink:
rollo
  • Rollo Audio Consulting -
« Reply #15 on: 4 Feb 2015, 03:48 pm »
  Nice industrial look. Are the RCAs silver or nickel ? Is the unit grounded or can it be ?
charles
tortugaranger
    • Tortuga Audio
« Reply #16 on: 4 Feb 2015, 04:05 pm »
charles
The RCA's are Cardas rhodium over silver over eutectic brass.
The ground from the 12 VDC power wall-wart PS is connected to a star ground point internally as are all audio grounds. The power jack is grounded to the chassis/rear-panel so the chassis should be at ground as well.
rollo
« Reply #17 on: 4 Feb 2015, 04:26 pm »
  Thanks for the speedy reply. Interest is perking.
charles
tortugaranger
    • Tortuga Audio
« Reply #18 on: 4 Feb 2015, 08:40 pm »
An additional pic showing live display.   :thumb:
TJHUB
« Reply #19 on: 5 Feb 2015, 03:14 am »
Thanks for the pic!  :thumb:
