Red Wine Audio Isabella replacement batteries
0 Members and 1 Guest are viewing this topic. Read 4315 times.
Rocket
« on: 31 Jan 2015, 07:35 am »
Hi Vinnie,
Absolutely enjoying my Isabella preamplifier that I purchased from you in 2014.  Just wondering where I stand with replacement batteries as the line is now discontinued.  Are they available anywhere or should I buy a pack from you and store it?
Regards Rod
Blu99Zoomer
Re: Red Wine Audio Isabella replacement batteries
« Reply #1 on: 31 Jan 2015, 05:17 pm »
Hi Rocket,
Good question.  I have a Signature 15 amp that I will need to think about its battery down the road.  I got mine last year, too.  So I hope a few years to wait for that time...Will it play off the wall a/c when the battery goes dead or am I going to have to play taps for the unit? :lol:
Best Regards,
Blu99Zoomer
Vinnie R.
    • http://www.vinnierossi.com
« Reply #2 on: 31 Jan 2015, 05:37 pm »
Hi Rocket and Blu,
Good question!  :green:
The battery packs in the Red Wine Audio LFP-V and Renaissance Edition products are custom-made for us (not an off the shelf
part).
I will continue to offer them for many years to come (including the custom aluminum casing that comes with the pack, so you
simply need the 4 bottom screws to mount it).
I do NOT recommend buying packs and storing them.  They need to be maintained (cycled, and not left uncharged for longer than a couple
of months).  I do all of that here, and have fresh packs or can get freshly-made packs them relatively quick.
Cheers!
Vinnie
Rocket
« Reply #3 on: 1 Feb 2015, 02:34 am »
Hi Vinnie,
Thanks for the information.  I haven't done any research but wonder how long in your experience do you expect the battery packs to last?
Cheers Rod
Vinnie R.
« Reply #4 on: 1 Feb 2015, 09:27 pm »
Hi Vinnie,
Cheers Rod
Hi Rod,
As long as they are used in accordance with the owners manual, they should easily exceed 1000 cycles (2000 is not uncommon).
A cycle being when you use your component on battery power, and then turn it off and it charged back to full capacity again.
Vinnie
Rocket
« Reply #5 on: 1 Feb 2015, 11:57 pm »
Hi Vinnie,
Thank you for the information.
Regards Rod
