0 Members and 1 Guest are viewing this topic. Read 13631 times.
Does anyone have any experience with OTLs like AtmaSpheres using an UberBuss? I have Richard Greys that don't seem to do anything for my M60 power amps, although they seem to help the front end. Just wondering if an UberBuss would help?
Definitely any transformer based gear will benefit from the "Cleansing Power of the Uber"... Dave - I think I just coined a "new trademark for you!!! LOL! My $0.02,Pete
The Uber seems to working with everything. However, my M-60's just didn't work for me no matter what I did with them.
My M-60s work great for me. Ralph Karsten suggested they respond to dedicated 20A power (check), good power cords, but did not recommend any conditioner other than something like this:Elgar 1 kW line conditionerWhich needs to be remotely installed due to the cooling fan noise, and burns quite a bit of electricity even when not in use, so I'd want to rig up some sort of remote switch for it. I'd prefer an easier solution that would work in-room like the UberBuss.I can't tell a difference between with/without aftermarket cords or the RGPC Powerstations. The good news it the amps sound sweet regardless of how they get their power.
So Charles, the conditioning of the Uber is in series, or in line then, right? If so, then I guess one for each component would be the ultimate solution. You would only need a single outlet on the back of each Uber or buss or whatever it is. If it were parallel conditioning you could just plug one (or two or three) of the devices into to an unused outlet and you wouldn't need any outlets on the actual Uber (or buss or whatever it is.)Just trying to understand the best way to use all of this stuff. Hope that is OK.
Now I'm wondering if I should daisy chain them instead.
Try it, but remember too much is not necessarily better. The MiniBUSS is a high quality extension with HF suppression, no PFC.Once again, every system is different. We don't have the same: grid; equipment; cabling; tastes. Trying every possible combination is the empiracle road to what works in THAT system.
I don't have a Mini though. Only Uber.
We can work on that for you
I know. That info was for clarity of Rollo's post.We can work on that for you
