Noise from D-200 Mk2 when switching on and off
0 Members and 1 Guest are viewing this topic. Read 1828 times.
ohlins
« on: 19 Nov 2014, 05:18 pm »
Hi Dusty,
One of my amps developed a problem recently: an audible pop from the loudspeaker when depressing and releasing the on/off switch...
I've tried applying contact cleaner on the switch but it did not really reduce the level of the pop  ...
Do I need to replace the small PCB if I want a new switch?
Thanks.
CIAudio
Re: Noise from D-200 Mk2 when switching on and off
« Reply #1 on: 19 Nov 2014, 05:35 pm »
Give us a call and we can help troubleshoot the problem.
Sounds like there may be some DC offset on the output (not a switch problem).
(805) 984-8282
