Piccolo2 PCB photo -dead channel
0 Members and 1 Guest are viewing this topic. Read 3195 times.
styliaddict
« on: 14 Nov 2014, 03:23 am »
I forgot to take a picture of the PCB before building. I am chasing the issue which has left the left channel dead. No sound at all. While I seem to have continuity & power throughout, I  cannot find a bad solder joint. The schematic refers to resistor & cap numbers and mine are obscured.
I note on the left channel I can measure a film cap at 114 nf while the right is 1.3nf. You cant measure capacitors while soldered in but this seems to indicate the signal is going to ground somewhere in this zone.
hagtech
    • http://www.hagtech.com
Re: Piccolo2 PCB photo -dead channel
« Reply #1 on: 15 Nov 2014, 03:15 am »
One possible explanation would be a 221 ohm resistor was used in the 221k spot.
jh
styliaddict
« Reply #2 on: 19 Nov 2014, 01:51 am »
Easy but embarrassing fix once located. Very quiet step up, nice detail & clarity.
