Sonore APPS - DSD2FLAC
0 Members and 1 Guest are viewing this topic. Read 53754 times.
vortecjr
  • the sound has to be in concert with the music....
    • Sonore by Simple Design
« on: 1 Nov 2014, 01:18 pm »
DESCRIPTION
Converts DSD to FLAC or  FLAC with DoP Encoding
*This application is provided as-is without warranty.
*Development for this application is closed.
*Please provide support to others via this forum.
FEATURES
Supports DSD input files in .dsf and .dff formats
Supports DSD64 and DSD128 input rates
Selectable output sample rates: 88.2KHz (default), 176.4KHz or 352.8KHz
Selectable bit depth: 16, 20, 24 (default)
Volume scale: -6dB to +6dB (+4 dB default)
Dither: on (default) or off
Optional output mode in DoPFLAC for use by a player that supports FLAC and a DAC that supports DoP input
Transfers stored metadata from the original DSD file to the resulting FLAC file
Single title conversion or entire album conversion in a given folder
SCREEN SHOT
DOWNLOADS
https://sonore.us
USAGE
MAC OSX
1. Download the application and open the folder
2. Right-click the dsd2flac_gui.jar and select open
Requirements: The dsd2flac file and the dsd2flac_gui.jar file need to be in the same folder, Java needs to be installed, 64 bit OS
LINUX
2. Right-click the dsd2flac_gui.jar, select Properties/Permissions, place a check in the Execute box, and press close
3. Right-click the dsd2flac_gui.jar select Open with other application and select Jave
LICENSING
Conversion based on DSF2FLAC, open source (GNU -V3)
Jave based interface Copyright © Simple Design, LLC
« Last Edit: 1 Dec 2019, 10:43 pm by vortecjr »
miglto
Re: Sonore APPS - DSD2FLAC
« Reply #1 on: 9 Nov 2014, 04:15 pm »
I'm having a crash problem... running dsf2flac in the shell produces the following output:
matildaX:ISO2DSD miguelito$ ./dsf2flac -i ./Tanguedia.dsf -o ./Tanguedia.flac
dsf2flac 0.1Rev30
Illegal instruction: 4
You can find crash logs at  http://goo.gl/Jlbrys
Thx!
totalz
« Reply #2 on: 9 Aug 2015, 04:49 am »
Will there be a Windows version?
Additional Sample Rates would be good too  : )
MisterEco
« Reply #3 on: 27 Aug 2015, 02:00 pm »
+ 1
franz159
« Reply #4 on: 5 Sep 2015, 03:27 am »
Great job!
Franz
104560616
« Reply #5 on: 22 Oct 2015, 12:44 pm »
+2
Phil A
« Reply #6 on: 22 Oct 2015, 03:39 pm »
+3 - would love to have that
Motoman4540
« Reply #7 on: 17 Dec 2015, 10:32 pm »
I have been using ISO2DSD and DSD2FLAC for several months.  I have a Naim NDX streamer, which can play DSD but the IOS app has not been recognizing the DSF files.  So I have been converting the DSF files to DoPFLAC rather than FLAC, and it has been working perfectly!  Thanks so much for your hard work.
PS  Is there a reason that the sampling rate is 176,400 rather than 192K?  I'm assuming so, and I don't have a clue whether there would be a sonic difference, but  . . .
ryanfu
« Reply #8 on: 15 Jan 2016, 08:41 pm »
Motoman4540,
Most DSD uses a base of 44,100hz.  This means that the sampling frequency is sequential multiples of 44,100: 88200, 176400, 352800, 705600, 1411200, 2822400 (DSD), 5644800 (Double-rate DSD)... and so on.
192khz is a multiple of a base 48,000hz: 48000 96000 192000.
Down-sampling from 2822400hz DSD to 176400hz PCM is very straightforward: divide by 16.  It is very important that the down- (or up-) sampled rate be an even division (or multiplication) of the original.
I can go into great detail as to why this is true, but dividing frequency by odd decimals (in this case 14.7) leads to quantization errors substantial enough to significantly affect sound quality.
While native 192khz is normally mathematically superior to 176.4khz, when the source is 282.24khz DSD, then 176.4khz FLAC will be far superior to 192khz FLAC.
davidavdavid
  • Music lover first, gear head second.
    • david.com
« Reply #9 on: 8 May 2016, 11:30 am »
DSD2FLAC is phenomenal
And I now understand why files folks have shared with me have this terrible crackle throughout. I did about half a dozen tests and found when converting DSF files and selecting FLAC/DOP it automatically converted at 176.4 even though 88.2 was selected.
The 88.2 conversions are perfectly clean. Totally quiet no crackling whatsoever. I thought this was an anomaly, but I was able to replicate across numerous folders of music.
This software really comes in handy when i bring files to my friend's house. He has one of those Schiit DACs and apparently their founder and lead designer do not believe in DSD; having yet to accept as their savior. Now I can head on over with these FLACs and play on his system.
mhconley
« Reply #10 on: 5 Jul 2018, 03:34 pm »
Resurrecting an old thread...
ISO2DSD is a FANTASTIC!
Now for DSD2FLAC...
Martin
