Source for cabinet for X-LX Encore kit
0 Members and 1 Guest are viewing this topic. Read 803 times.
Whitestix
« on: 31 Oct 2014, 01:15 am »
I have no ability to fabricate an enclosure for this speaker so I am seeking a source for a pair of them, either a flat-pack or, preferably, finished enclosures.  I built the LGK speakers and am extremely happy with the sound of these small speakers.  I suspect the Encores will be much better.   Thanks for any suggestions.  Mark
Re: Source for cabinet for X-LX Encore kit
« Reply #1 on: 31 Oct 2014, 01:56 am »
Mike (mlundy57) will build you a finished pair.
You can also use the Parts Express cainets (.5 cu ft)
I believe these are the ones some of the guys have used
http://www.parts-express.com/dayton-audio-tw-050bk-050-cu-ft-2-way-speaker-cabinet-gloss-black--302-720
You can also get a veneered model.   Just be sure to line them with a sheet of no rez from Danny, goes for all these  :)
I thought Ben (baniels) at one point had been talking about doing a run of the X LS Encore flat packs but I don't see them on his site
Rubae (outofthewoods)  had  flat packs but  they are probably all gone.  He's another guy to ask  if  he plans to  cut another run of them
Edit: Almost forgot the Skiing Ninja  (the ninja)
-jay
« Last Edit: 31 Oct 2014, 03:17 am by Captainhemo »
