We are carrying DuraTex Coatings.
0 Members and 1 Guest are viewing this topic. Read 23311 times.
mlundy57
Re: I am carrying DuraTex Coating.
« Reply #20 on: 26 Nov 2014, 06:31 pm »
I'm building a pair of LXmini speakers, and the mid woofer sits on top of 4 inch PVC.
I was going to paint the PVC, but has anyone tried DuraTex on PVC?
I think it would look great  :thumb:
Mike
I haven't tried the Duratex yet either but if scuffing the PVC isn't enough for the Duratex to hold you can always put a coat of primer on the PVC first.
Mike
Atlplasma
  • Just off the boat
« Reply #21 on: 26 Nov 2014, 07:38 pm »
Mike
Hi Mike.
I'm considering that build as well. Please post your feedback on the LXmini (http://www.audiocircle.com/index.php?topic=129952.20) after you're done.
corndog71
  • Some people call me Rob.
« Reply #22 on: 22 Dec 2014, 06:09 pm »
A few years ago I built my first sealed servo subwoofer.  Wanting to be different and having novice woodworking skills I opted to build a tube made up of over 30 MDF rings.  For the longest time it went unfinished as it still looked cool if a little rough around the edges.
After practicing with the duratex and getting a better handle on how best to apply it I opted for a somewhat smooth finish along the outside of the cabinet and textured the bottom.  I think it turned out ok. and now I'm not worried about it ever getting wet.   :thumb:
gab
« Reply #23 on: 20 Jan 2015, 07:10 pm »
I just got through using the "spray version" and applied it with a 1/4" nap roller. The stuff works great! Attention to prepping the cabinet is well worth the time spent for a nice light texture (any surface anomalies from a not perfect prep will show up).
A little of this stuff goes a LONG way. I still have 3 quarts left over after doing four 14"x14" cabinets. Call the manufacturer if you have any questions. They are extremely helpful.
gab
« Last Edit: 21 Feb 2015, 11:35 pm by gab »
Danny Richie
    • http://www.gr-research.com
« Reply #24 on: 22 Feb 2015, 02:00 am »
I still have the pint and quart sized versions with rollers in stock. This is really good stuff.
Oscillate
Re: We are carrying DuraTex Coatings.
« Reply #25 on: 19 Oct 2015, 11:41 pm »
"If you roll on several lighter coats a smoother surface can be achieved."
I have a question regarding this textured finish and just how it
might affect the drivers sealing tightly against the baffle? Is the
the solution just not to do a 'texturizing' final pass with the roller
on those areas? ...Thanks
Phil A
« Reply #26 on: 19 Oct 2015, 11:44 pm »
Beautiful job on the sub.  Where did you find the mdf rings?
Folsom
« Reply #27 on: 19 Oct 2015, 11:48 pm »
Find?
Danny Richie
« Reply #28 on: 20 Oct 2015, 12:05 am »
My surface mount woofers have a pretty good gasket on them and I have not seen any issues with them so far.
Anything that is counter sunk like tweeters or the LGK's does not get a layer of Duratex inder them.
