Poll
What is amplifier bias
I think it is very important to get just right
1 (6.3%)
Close is good enough
6 (37.5%)
Set the meter to mV
2 (12.5%)
The right bias comes from a design equation
3 (18.8%)
We are measuring what is traditionally called "bias"
3 (18.8%)
Set the meter to mA (milliamps)
1 (6.3%)
None of the above,  I have a question
0 (0%)
We are not measuring what is traditionally called  "bias" but something else
0 (0%)
Total Members Voted: 10
Voting closed: 25 Aug 2014, 03:17 am
Amplifier Bias
0 Members and 1 Guest are viewing this topic. Read 15569 times.
Gearmonster
Re: Amplifier Bias
« Reply #40 on: 26 Sep 2014, 06:50 pm »
eno, did you get this worked out yet, You can write tubeaudiostore@gmail.com and Roger or Ben will help you.
enochrome
Re: Amplifier Bias
« Reply #41 on: 29 Sep 2014, 04:29 am »
Sorry, I was away for a bit.
It turned out well. Listening to music now. I have realized that they are not a good fit for my speakers and I think the preamp was not a good match. Using the preamp from my integrated was more agreeable . I am going to keep one of the RM-10's and use it with a fullrange project that I am about to begin. I do like the sound of the amp; it is sooo composed, has body, and avoids the syrupy characteristics of poorly constructed tube amps. I thought RM 10's low end is outstanding, better than that of a primare a30.1 that I had, and that was dual mono. :roll:
Thanks everyone for helping me with this. I will post upcoming results with my speaker project. I also will combine the amp with a First Watt B1 in the future and let you know how that sounds.
Cheers
