0 Members and 2 Guests are viewing this topic. Read 105149 times.
I recently bought a pair of Avalon Opus speakers, with ceramic mids and tweets and a dual 9" woofer system. Like many Avalons, they are known as a finicky speaker to get sounding right. They are easily the highest resolution speaker of the 250 or so pairs I've owned, which cuts both ways, of course.Today I got the King Maraschinos up and running, and they are everything I wanted and more.What a g** d*** superb amp!The Avalons are now singing like nothing I've heard in my home in my 49 years in the hobby.Transparency, image depth, width and solidity, bottom end control. Beautiful detail, air, and delicacy on top. All aces. Perfect immediacy and astonishing detail, yet with notably less brightness and glare. The whole enchilada. I've probably owned 75 good amps over the years, too, and heard a great many more. Matchups tell the final tale, of course, but these little guys stand tall with anything I've heard at $10k or under, IMO, and would embarrass some MANY higher priced units.My simple advice if you are looking for a truly great amp that will do justice to even the finest speakers- just contact Tommy and try one. Pretty simple, no brain required.
The top-end is the best I have heard from a Class D amp so far. It is nicely textured and extended, but compared to my reference Pass 30.8, there is an ever so slight amount of homogenization in the upper octaves, but it is ever so slight.The top-end is nicely detailed, and it has no glare or edginess. The truth is that it is quite beautiful.The other thing I would say about the MEGAschino is that it has great attack and definition in the midrange without sounding aggressive or the least bit “transitory.” It sounds smooth throughout its frequency range, and it also seems more tonally accurate than other Class D amps. For that matter, it also sounds better than most transistor amps. Vocals were played with an incredibly clear window on the performance, and instruments seemed to be right there in the room with me. Vocals also had good body and weight.It has a bit of the bloom in the midrange that I most often associate with single-ended Triode tube amps. It also lets you hear the layering of the music like SET amps. Now don’t get me wrong, the MEGAschino will never be mistaken for a SET tube amp, but it does give you just a touch of their magic but with much more power. I was rather surprised by this...
Stereo MEGAschino: $6,100MONO MEGAschino: $9,800/pr or $5,000
