RM200 Mk.II Owners Manual
0 Members and 1 Guest are viewing this topic. Read 3306 times.
bdp24
« on: 22 Jul 2014, 03:04 pm »
Does the Mk.II version of the RM200 come with an Owners Manual specific to it, or is it the same as the one that was included with the original version?
tubegroove
Re: RM200 Mk.II Owners Manual
« Reply #1 on: 22 Jul 2014, 05:46 pm »
I believe it is a common manual that reads Music Reference RM200 MkI and MkII on the cover.  Differences in the MkII are highlighted where necessary
Roger A. Modjeski
« Reply #2 on: 23 Jul 2014, 07:07 am »
There are slight differences. What do you want to know?
bdp24
« Reply #3 on: 23 Jul 2014, 03:15 pm »
Since I don't know what the slight differences between the two manuals are, I don't know what I want to know! I just want to have the owners manual for the amp, and have the extra or different information that is in the MK.II manual. But I'm confused---yesterday you said there was only one version of the manual, that it came with both the original and MK.II versions of the amp. Now you say there are slight differences. Are you talking about the two different manuals, or the amps themselves?
Roger A. Modjeski
« Reply #4 on: 23 Jul 2014, 03:19 pm »
Does your manual describe the forming switch? If so it is a MKII manual. Only the MKII has that switch.
bdp24
« Reply #5 on: 23 Jul 2014, 03:25 pm »
No, it doesn't. Is there a printed copy of the manual I can order from Ben, or a jpeg only? Thanks---EJ.
Roger A. Modjeski
« Reply #6 on: 23 Jul 2014, 03:30 pm »
write him at tubeaudiostore@gmail.com
bdp24
« Reply #7 on: 23 Jul 2014, 04:10 pm »
Great, thanks Roger.
bdp24
« Reply #8 on: 15 Aug 2014, 06:41 am »
For any owner of the RM200 MK.II amp who doesn't have the later version of the owner's manual, I urge you to email Ben and request one. LOTS of additional information of interest in it.
