0 Members and 1 Guest are viewing this topic. Read 5187 times.
Where can I find a re-foam kit for the 15" passive radiator?Also, who manufactured this PR? (out of curiosity)Thanks
If it is helpful, I have one (1) NOS 15" Passive Radiator for $39 plus shipping.
The old one would bottom once in awhile while I have never bottom the new one.
I wonder if this surround might not work better for the passive radiator. It's a 'large roll' surround. This makes me think that it might allow for longer cone excursion, before bottoming out. Though, the passive's spider might be what determines cone excursion? But, either way, it's only $11.95, so it's not like you're out much dough, if you try it! http://www.speakerworks.com/15_Large_Roll_Angled_Speaker_Repair_Kit_p/swk15alr.htm
I am messaging Sean at SS now for his take. Will let you know what he recommends.
Dont bother fixing the old PR's they pale in comparison to the new ones/replacements....Contact John Casler....
Hi John,Is that the 15" size that you had mentioned with one remaining?
