0 Members and 1 Guest are viewing this topic. Read 17359 times.
for safety's sake, the caps should be X2 rated.-Lost81
Quote from: Lost81for safety's sake, the caps should be X2 rated.-Lost81Lost,.... I'm at a loss.... This is not an 'accross the line' situation, nor to my knowledge, are there any caps appropriate for the task that are rated such. Please read the DiyAudio thread. But in reality you are correct, my cat, my wife, etc... should all be rated X2.
I started that thread on AA. I probably should have brought it here in the first place.My aksa transformers hummed when I first built them some time ago, and it went away for a while, and now it is back. It seems to be worse in the evening when usage of the grid is at its highest. That seems like a simplified ersion of the circuit on diyaudio.com. (it's from: http://diyparadise.com/dablok.html)Since I am a total novice, could someone give me a bit of guidance about what caps and diodes I would need for 120?Thanks.
Hi Steven,You are dealing with a potentially deadly voltage! ...
Quote from: JensHi Steven,You are dealing with a potentially deadly voltage! ...C'mon, Jens,"Ordinary Men" are quite happy brushing their fingers across AC terminals and delighting in the kick which their fingers get!!"Real Men" delight in putting their tongue across AC terminals!! What are ya, a man or a mouse!!Regards,Andy (an ordinary man)
