0 Members and 1 Guest are viewing this topic. Read 3305 times.
Not that great sound at an audio show is a big deal or anything, but. . . . . . place any bets on how fast every decent hotel in the USA gets at least one of these in every guest room?Well, if there were at least 87 audio companies doing shows, at least you could probably make your minimum order with a reasonable backlog of customers.
Okay, gang. Here's a question from the ignorance camp: What is it about USB that is so noisy?
Dave,Thanks. That helps. It also helps explain why my UberBUSS will have to be pried from my cold dead fingers before I allow it out of my house. I've already begun considering ordering a second buss (mini or majik) from you. I'd take that one to Taiwan with me. Can you make a mini-UberBUSS with 4 receptacles instead of 6?Just yesterday, I decided to buy a Mac Mini to replace my aging (and gawdaful noisy) PC. [Pats self on back]
Dave,I just put my power regenerator on my tube guitar amps to kill off the light dimmer noise in the house. Even full on they are terrible.DC on the AC lines is getting worse. I will be looking at the new device to work with the stereo PA's instead of the power regenerator.Just one voice out in the boonies.
What I don understand is why a re-generator would need DC blocking ability (which PS Audio inculudes) when it is supposed to "make clean power" e.g. AC > DC > AC. If you have read my thread you know DC on the lines comes right through my P3 and out my speakers. Not a ground loop as switching to a new power leg fixed it.
Oh, goody! I get the first MiniUberBUSS (MUB?) My Mac Mini will have the upgraded 2.6 Ghz i7 processor and 8 GB of RAM. That should be enough power for a good long time. I'm developing an addiction to high quality power cables.
What's the pricing on the MiniUber? Also, what are the dimensions and weight?
I think that I am going to replace the RevB with the MUB and call it RevC. I sell 25 times more UberBUSSes than RevB's. Available upon request like all of my gear. It will be housed in the same case as the RevB. I measured everything last night and I can fit everything in the case with a gnat's butt of clearance. If the size of some of my components change I will have to rethink that. Size is 5.375 x 5.375" x 10.5". Weight will be about 9.5lb.Pricing is TBD and not that much less than an Uber. The savings are one receptacle, the components in the final filters, a couple of pieces of wire, a few square inches of Medex and a little paint. Labor will be about the same.
OK. So go with an Uber unless size is an issue. Got it.
