The
HIGH END Line by NuPRIME is starting to grow.
First we saw the new
REFERENCE 20 monobloc amplifiers with 420wpc each and now one of the best ever products called the
IDA-16.
IDA stands for
Integrated Digital Amp.
This amp is SMOKIN!!
With the incredible success and acceptance of the DDA-100 the IDA-16 steps even further into HIGH Performance. Audiophiles LOVED the DDA-100 but in reality is was only a candidate for small systems, or systems with exceptionally high sensitivty speakers, due to the lower power ratings.
Well the IDA-16 changes all that. At 200wpc it will cruise right along with most any speaker in most any system.
But it doesn't stop there. The DAC chipset is the ESS SABRE and implemented in the best NuPRIME (high end) fashion, along with the tried and tested "Cross-Matrix Capacitors", Super Quality Op amps, and the best Volume Control known.
Oh did I forget, it is the
world's first fully integrated digital amplifier offering 384K & DSD decodingBelow is some of the information to this stunning new offering:
Features:Full microprocessor control with memory retention
Five digital inputs & one stereo input for complete system flexibility
Supports DSD native playback by ASIO2.1 and DoP method
Theater-Mode pass-through (fixed volume control) function
Ultra low noise JFETs employed in input stage for the lowest possible noise performance
Volume adjustment in 99 precise, 0.5dB increments
Advanced, thin-film switched-resistor ladder network for controlling volume - only a single resistor in the signal path at any volume setting
Individually adjustable volume on each input for precise level matching of all sources
High-standard parts: USB (DSD): XMOS DAC: ESS9018 and OPA2134 for high-quality sound.
Cross-Matrix Array (CMA) capacitor module
Exclusive driver software for Windows
Standard driver software for Mac
Asynchronous transfer mode
Very Low Power Consumption on Standby Mode
Available in stylish black or silver anodized aluminum finish
Included remote control for full convenience
INPUTS/OUTPUTSInputs:
(1) USB Digital
(2) Coaxial Digital S/PDIF
(2) Optical Digital S/PDIF
(1) Analog Stereo RCA
Outputs:
(1) Optical (up to 24 bit/192 kHz)
(1) Stereo RCA (Line out)
(1) Stereo Speaker (Binding Posts) Output
SpecificationsUSB Sampling Rates:44.1KHz, 48KHz, 88.2KHz, 96KHz, 176.4KHz, 192KHz, 352.8KHz, 384KHz and DSD 2.8MHz, 5.6MHz
S/PDIF Sampling Rates:44.1KHz, 48KHz, 88.2KHz, 96, 176.4KHz, 192KHz
Maximum Sampling Rate:24-bits
Bit Resolution:16-24-bits
Power output:200W x 2 (8-Ohm)
THD+N: 0.004%
Peak Output Power:400W
Frequency Response:10Hz to 80kHz
RS232 extension:Smart Home Control & Firmware upgrade
Dimensions:17 in W x 15 in D x 1.97 in H (2.56 in H include feet)
Weight:16 lbs.
