How to get 100 DSF files into J River 18 library?
0 Members and 1 Guest are viewing this topic. Read 1125 times.
Brucemck
« on: 30 May 2014, 10:31 pm »
I'm running J River MC 18 within a 64 bit Windows 7 environment.
I have already set the file associations to include DSF files.
I can not import DSF files. However, when I double click on a DSF file directly it will open up and play in J River.
How can I get those DSF files into my library?
ted_b
Re: How to get 100 DSF files into J River 18 library?
« Reply #1 on: 30 May 2014, 10:36 pm »
Download and watch my screencast tutorials (part 1 and 2) and lemme know if they address this.  They should.  Your DSF folders should be pointed to in the import process.
http://www.audiocircle.com/index.php?topic=121419.0
Brucemck
« Reply #2 on: 30 May 2014, 11:05 pm »
Pointing Auto Import to the folder did the trick. Thanks!
Still, it's very odd that I can't use the "Library Import A Single Folder" command, point to that exact same folder containing DSF files, and have it work!
sts9fan
« Reply #3 on: 30 May 2014, 11:11 pm »
Or just go to the jriver wiki and learn in a few sentences. Way quicker.
http://wiki.jriver.com/index.php/DSD_Format
ted_b
« Reply #4 on: 30 May 2014, 11:17 pm »
Thanks sts9fan, always appreciate the support.  I put the screencasts together on my own time, to help folks get a large breadth view of how to use JRiver.  Yes, you can go to the wiki and learn this one issue.  Of course you can.
Bruce, glad my "point to it in import process" worked.
sts9fan
« Reply #5 on: 30 May 2014, 11:37 pm »
You mad bro? No need, all I said is that it is faster.  The wiki is very good.   I am sure the videos are great.
ted_b
« Reply #6 on: 30 May 2014, 11:57 pm »
No, it was a bad attempt at a little poke...my bad.  :)
sts9fan
« Reply #7 on: 31 May 2014, 12:22 am »
Happy Friday!  :thumb:
