0 Members and 1 Guest are viewing this topic. Read 6956 times.
I just replaced the blown L-pad with Parts Express #260-265. Woofers and midrange are working fine, but the tweeter is still dead. Nothing else in the cabinet seems to be blown out, the tweeter itself looks undamaged but I can't think of anything else other than replacing the tweeter. Anybody knows of where to purchase a new tweeter and how to install it? Thanks!
The tweeter is fine, I've just replaced the other L-pad, no sound from the tweeter. So I pulled out the capacitor and it is blown on the side that was glued to the cabinet, so I couldn't see it while it was still attached to the cabinet. This is the photo of it. The only inscription on it is 1.3.. nothing else.... Anybody knows what is this and where can I buy it? Thanks guys!
If the ribbon is not blown, it is likely that the crossover capacitor for the tweeter has opened and failed. If you have the reddish capacitors in your crossover, these are TRT Dynamicaps (available from Parts Connexion and Michael Percy Audio). I dunno if Brian ever built RM/Xs with the cheaper Auricaps. In any case, look for the single cap (not the midrange multiple bundle) that is wired between the lower positive midrange/tweeter binding post and the tweeter L-pad. It should have the value in microFarads (.XX) handwritten in black magic marker on it. You need a digital multimeter with a capacitance measuring function or a capacitance bridge to check that it still yields the written value (it can only be measured if at least one end is detached from the speaker crossover). If it isn't marked, ask for this value at this board because it was a standard parallel 2nd order 7kHz crossover used for this tweeter on several VMPS model (I don't remember the value of mine). If the cap is bad, you can cut it out and solder a replacement in, but note that these take a lot of hours of play to burn-in before the sound opens up.
Stimpy, yes, I followed Steve's instructions to the letter. The problem is that the TRT Dynamicap 1.3uF capacitor is not available for sale on any of the suggested web stores. So the only route is to try to custom order them directly from the manufacturer. And yes, they seem to have an upgrade to Dynamicaps, the TRT StealthCaps, so I'll probably try these and replace them in both speakers.
