0 Members and 1 Guest are viewing this topic. Read 7826 times.
The original Dream Maker LCS effects speakers, or perhaps a scaled-back version, could be added to your Planetarium Alphas, so you could sort of have your cake and eat it too.
Dimensions in preferred setup: HWD 10 x 20 x 28
I'm curious, just off the cuff, how small could the effects speakers be scaled to? What would be lost in the process? (I'm assuming bass extension, for starters)
Duke, is LCS radiating with same SPL as front speakers? Or perhaps it is a bit quieter?
Duke/Jim, A buddy asked me a question. "If a speaker can benefit from a delayed ceiling splash, can a speaker also benefit from a delayed floor splash." He assumes that the flooring material is non absorbing tile or wood. My answer was hmmm... I don't know, but I'll ask somebody. The concept might be viable where speaker size or placement may be an issue. Also furniture might get in the way. Guys? BTW I've tried splash speakers before and have listened to designs by Lowther, Allison, Linkwitz, and a few others who used up firing drivers, but none who tried to physically maximize the delay. This is intriguing stuff.Steve
Duke,Does the ceiling that the LCS speakers bounce off of need to be parallel with the floor? In other words, would these still work with a left to right upward sloping ceiling? Are the timing delays simply a function of relative placement or is it done with some electronic delay?Cheers,James
Duke,Any success in scaling down the LCS effects speaker and hopefully making it compatible with your older designs?Thanks,Boris
Do keep us posted Duke!
James, you say you ab'd the little t amp against the modified pioneer 912 but you didn't say how it compared. I'm curious because I own (and am very happy with) the very same modded 912.Brad
