0 Members and 1 Guest are viewing this topic. Read 6576 times.
Class d? Hypex UcD or ?
Lastly they are modified by Merrill Audio.
These are Hypex modules that originate (as they all do) from the Ucd. There is some new tech in them as well. Lastly they are modified by Merrill Audio.Regardless of architecture, the Monoblocks should be listened to and compared to anything else out there to make up your mind. DBT would be best to see which sounds best!Enjoy.
What mod(s) are performed? Does this void the Hypex warranty? Which module are they so I can see the measurements before modding? Do you have the AP measurements post modification?
I would reckon Merrill Audio would cover the warranty period, since it is their amp.
Most audiophiles buy gear base on how it sounds (assuming it measures well).
I seriously doubt Merrill would offer up the amps if they thought there would be issues. Rowland has been modifying Class D amps for years without issues. Don't see why this would be any different.I would further argue one can't get a full sense of how an amp will sound just by measurements. Granted, it needs to measure well to to be able to sound good, but many of the Class D amps I've auditioned measure well, but were lacking in one or more important area sonically. The vast majority of measurements are single frequencies through a static resistor. That is most helpful, but not necessarily tells you how it will sound. As stated earlier, the best sounding Class D amp I've heard to date is the Yamaha MX-D1. I suspect the key to the Yamaha's outstanding performance is the unique input signal processing (using digital flash vs. analog). No reason not to think that improvements can't be made by upgrading/modifying the input buffering.
