0 Members and 1 Guest are viewing this topic. Read 140769 times.
It is the stand-by transformer. So it is always ON if the unit is plugged into a live AC outlet, and supplies a voltage to the microprocessor so the unit can turn ON via the App, , the remote or by pressing the momentary push button on the front panel.
Hi Vinnie, this is great news coming from your camp - thanks for it! I feel very excited but in fact I didn't expect anything but improvement with your output I/V stage and hope it will be even bigger in "stage 2" with the modded PSUs - looking forward to it!A side question for your tube stage, please - you already mentioned you removed a 'lytic cap from the signal path (thank God!) but will there be any other input, output, feedback caps in your output stage that can be changed for different sound presentations, please? I am sure I have an input cap on my power amp so if you have an output one it could be safely bypassed, I suppose?Thanks!Ivo
Is the stand-by transformer an universal transformer? I.e. accept voltage input between 100V to 240V, etc. is yes, I might be able to custom-made transformers to replace the two stock transformers to suit my local voltage.
Are you able to extend the tube option to all 12A family, i.e. 12AT and 12AU as well?
My amplifiers is fully-differential therefore I'm only keen in BAL mod.
Fascinating thread, Vinnie. The tube stage you are using, since you have not said or suggested it, I gather it is not the same as your "New Renaissance Edition tube stage", or is it? If not the same, how do the two compare...would it make sense (if possible at all) to include the "Renaissance version" as an available option to the Sony mod?
One more thing--just curious--on the same subject of adding the tube output stage to the Sony, what is the advantage over using stock unit with a world class tube preamp like, for instance, your very own new Isabella ?
Hi Ivo,As far as the other caps, there is one built onto the tube stage board. But I don't recommend playing with it. Instead, what I recommend is TUBE ROLLIN' to fine-tube the sonic presentation. - Vinnie
Vinnie,How many hours does it take before the hap is burned in? I was very delightfully surprised at the big soundstage the Hap had right out of the box.
Hi Vinnie, I definitely will try the tube rolling and since I am located in Eastern Europe I might try some Russian tubes too which are cheap and widely available around here.
Hi Peter,No, it is 120V. There is no universal power supply (no switching power supplies) in the Z1ES to allow for 100-240V universal operation.I believe so, but I might have to change some parameters on the tube stage boards and test (if this is really important to you).
Hey Tom,Been waiting for you to chime in since it was mentioned that you had ordered one.How about some comments and maybe comparisons with what you have been using until now or have used in the past. Looking for feedback mainly on sound quality as we have a pretty good handle on functionality.Come on - spill the beans!!!Cheers,Dave
If one were to tube rolling, I believe that he/she would be curious enough to try all possibilities. Moreover, 12AXX family is widely available worldwide, especially true in US. So make the tube output stage as universal as possible would be an added advantage.
I was hoping you could change volume with the app, so Vinnie needs to add volume control to mine.Let's see, tube mod plus volume control and probably the battery mod. I have a lot of SLA batteries sitting around the house. Will we be able to use the battery mod with those type of batteries?
I understand. I'll need to test others in the 12AXX family to be sure, but for now, 12AX7 works great.
Hi Vinnie, I definitely will try the tube rolling and since I am located in Eastern Europe I might try some Russian tubes too which are cheap and widely available around here.Thanks!Ivo
Do you've the stock unit enough run-in, you may leave it on 24/7. My unit just sounds gorgeous! Should have passed 250hrs by now.Is there any sonic advantages if the unit run in full battery mode?
I'd suggest you to get a used unit (cheaper price) from US, and send it to Vinie for mod (one way ticket to Euro only).
Vinnie, congratulations - very nice looking and well made mods - thanks! And yes, the quality still comes with price and I need to save even more now...Question about the output board, please - will it be able to drive directly power amp/headphones when volume pot is installed or additional buffer/pre-amp board still will be required, please?
